| ossiblue |
01-27-2016 06:03 PM |
Originally Posted by MattTHEpainter
(Post 8974648)
Thanks guys I really appreciate the quick responses! Matt, what do you mean by "type number"?
Check the link posted by Jeffs914s, it's in German but you can figure it out. 3rd chart down, look at the "motor" column and you'll see numbers like 911/07--those are the engine type numbers which are found stamped on the engine case, on the flat, to the right of the engine number you posted.
From your number, the engine looks to be for a US sportomatic, but the type number will confirm that if it is 911/08.
Edit: use Joebob's picture to locate the type number.
