Engine number decode
I have searched a few resources to try to decode this motor serial number, but no luck. I would greatly appreciate if someone could point me in the right direction. The number is "6106197".
Thank you in advance, Matt |
gearhead
Should be a 1970 911T. Is there also a type number? That would tell you for sure.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
RETIRED
A 3 digit number then a / and a 2 digit number, lighter stamping on the side rib to the right of the pulley.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
From your number, the engine looks to be for a US sportomatic, but the type number will confirm that if it is 911/08. Edit: use Joebob's picture to locate the type number.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Thanks again guys, much appreciated.
