Can someone explain why "heel & toe"
Considering I been driving a Porsche for at least 20 years, this may be a dumb question. What is the purpose of heel & toe?
I recently watched a video on the new Porsches, specifically on a European 911 Targa that still had a manual transmission and the driver was commenting that the transmission had an auto "Blip" feature that revved the engine during shift changes which eliminated the heel & toe need. (BTW, he also commented that this in no way compensated for the worthless 450lbs extra weight of the new targa system). 1) I've always wondered why racers revv during shift changes 2) I've always thought this was something needed specifically on turbos where you wanted to keep the turbo spooled up during a shift change but I'm not sure how needed this is for a N/A engine. Can anyone give me a simple explanation - just for my own education. |
The "blip" that heel toe creates is an attempt to match engine and transmission speeds. If you don't blip, you get that lurch forward which upsets the balance of the car. In a perfect heel toe downshift you feel nothing and it feels wonderful. So, as the car is being slowed with part of your foot on the brake the other part of the foot hits the accelerator (blip) while nearly simultaneously, but not quite, the clutch is let out.
When you do that in your car you are not only effectively encouraging the rear tires to break traction, but you are being very hard on the gear box too. By blipping the throttle you are trying to match engine speed to where it will be once you let out the clutch. Thereby smoothing the entire process for the transmission and grip of the tires. If you are on the limit, not doing this will cause you to spin out and possibly crash. If you are in traffic, it's still nicer on your transmission and it's fun practice. The 911 is one son of a ***** to Heel Toe. I can heel toe a Landcruiser more easily! However, I still, always blip the throttle when down shifting. I love my car. |
Heel/toe rev matching is done on downshifts to match revs prior to shifting into the lower gear. On a track, you want to brake as late as possible out of a straight and simultaneously downshift so that you're back in the powerband coming out of the turn. Doing this simultaneously (breaking, rev matching and depressing clutch) would require 3 feet, so one combines the braking and rev matching with one foot.
If done in conjunction with "double clutching" (depress clutch, take car out of gear, rev match and then engage clutch and put back in gear), this will save wear on synchros. Otherwise, heel and toeing simply assures that the drivetrain doesn't need to absorb the shock of bringing the engine up to speed. |
Blip
I think that blip is pretty much not very noticeable, and most people do it fairly automatically. I only ever really "hear" it for a downshift, when you're trying to downshift for acceleration, not because you're reducing speed.
But I've actually been wondering some of this myself. I've driven a stick since I learned to drive, but I've always wondered if I do it optimally. |
Simple answer is it's hitting all three pedals at once, but the throttle only as much as needed.
http://www.trackhq.com/forums/attach...ltoegif4ty.gif I tend to prefer to use the right side side of my right foot rather than my heel, assuming the pedals are close enough. It's a really difficult art to master, but very useful at 10/10ths. I suck at it. http://49.media.tumblr.com/2aba037e2...zkooo1_400.gif |
+1 on darrin's last paragraph.
When teaching my granddaughter to drive the 911, I had her shift between 1st, 2nd and 3rd while maintaining the same speed. By double clutching, if done right, you should not feel any jerking or a change in vehicle speed, only the sound of the engine. Drive in both 2nd & 3rd at a certain mph; note the rpm at each speed; when in 3rd, put in clutch, rev to the rpm it was in 2nd and it should drop right into gear. Then try the same method using 1st and 2nd. A little practice and Bob's your Uncle! |
Heel and toe is super easy to learn, *if* the pedals are set up properly for it.
I have an old BMW that has the gas and brake pedals in perfect position for heel and toe. In that car, I heel and toe every downshift. I do it automatically now, without thinking about it. It's fun when you hit it just right and have a super smooth corner entry downshift. Technically, it's a little easier on the drivetrain, I suppose, too. Air cooled 911s, I think, have some pedal adjustability, but I don't think there's enough to get it really perfectly "right." The gas pedal is usually way too low. At least in my car it is. I've seen lots of aftermarket gas pedals available, with adjustability. Those seem designed mostly to make heel and toe easier. Once you learn it, you can do it in any car, even with poorly set up pedals. But it's not as fun or easy. |
I'll try explaining mechanically what the objective is.
If you ever try shifting from 2nd to 3rd with no clutch at all you learn that to get it out of 2nd you need to match engine speed precisely with wheel speed. You put a tiny bit of pressure on the shift lever towards neutral and the minute the engine speed matches the wheel speed magically the gear lever comes out of 2nd and into neutral. It's that speed match up between the engine and wheels your looking for. OK, so now onto the next harder part: now that we are in neutral we want to slide into 3rd but without using the clutch. What needs to be done here is to precisely anticipate the engine speed needed to match the wheel speed for 3rd gear. Once that engine speed matches the wheel speed the 3rd gear engagement can now be done. I shift my 5 speed VW Passat this way often with no ill harm. So in the heel toe approach it's mainly used for down shifting in an attempt to get engine speed at or slightly above the target RPM for the lower gear we are shifting into. You may better understand the concept by understanding double clutching as seen here: https://www.youtube.com/watch?v=zy0BfG_CG2Y The explanation starts around the 6 minute mark. The vid is long but he does a decent job at explaining it. |
I think the answers above have failed to explain the whole reason for 'heel and toe'. 'Heel and Toe' is generally used to down-change gear whilst slowing for a corner in order that you are in the right gear to accelerate out of that corner. You want to be in the right gear and at the right speed to enter the corner, hit the apex and accelerate out/through the corner.
You lose precious time changing gear or braking and not doing these things at the same time. 'Heel and Toe' enables you to slow and change gear at the same time. Firstly the 'heel' is used to blip the throttle to enable rev-matching during a change down in gears (for the same speed the engine needs to rev higher to have a smooth down change) Secondly the 'toe' is used to simultaneously apply the brakes I have always rev matched by blipping the throttle on down-changes in order to sympathetically change gear but I have yet to master the 'heel and toe' method. This is one of the things I am going to concentrate on to learn correctly. Cheers, Neil |
If you are in fourth and you want to come out of the turn in second, do you utilize third gear on the way down to 2nd to scrub any speed off? |
Just blipping the throttle gets the engine to speed in anticipation of the lower gear. But the main shaft in the tranny is still spinning to slow compared to the intermediate shaft that's directly connected to the wheels. So when you blip the throttle you get the engine speed closer to the wheel speed for that lower gear.
But you still have the main shaft in the tranny sort of spinning in limbo, it's not connected to either the motor or the wheels if the clutch is in. So the heel toe helps align engine mass rotational speed with the wheel speed for the down shift and the engine has the grand majority of mass so it really helps. But the main shaft still remains at a lower speed and will be brought up to speed on the engagement of the clutch. While double clutching results in bringing both engine and main shaft up to speed because in the double clutch scenario you slide into neutral, release the clutch and then blip throttle. Here both the engine and the main shaft come up to speed. Then you move clutch back in and select the downshift gear. But double clutching is very time expensive so heel toe is a trade off between getting the majority of the mass (engine mass) up to speed in favor of time. We trade off time for the main shaft speed. Hope that helps. |
If you are in fourth and you want to come out of the turn in second, do you utilize third gear on the way down to 2nd to scrub any speed off?[/QUOTE]
I believe that slowing down is the sole job of the brakes in the vast majority of situations. And to your question, not necessarily. If you have perfect synchros etc you could go direct to 2nd from 4th but definitely with the aid of heel toe to avoid the engine adding additional force on the driven wheels and upsetting the balance or causing momentary lock up. |
This guy covers both the simple heel toe and the heel toe with double clutch
https://www.youtube.com/watch?v=ucwtXkCfcbI He does a very good explanation and demonstration of both techniques. Very hard to master! I understand the concepts but I'm not a master :( |
Upsetting the balance/lock-up...............At my one real track event, I overheard old timers talking about new kids with monstro cars and they have yet not learned car control. These things have to fall into that category |
Bob and others, changing gear from 4th to 2nd via 3rd wouldn't be particularly useful and you should be able to go from low revs in 4th to high(ish) revs in 2nd without an dramas. I don't believe you should be slowing when in the corner itself apart from initial trail braking as you commence the turn. You want to be on the power through the corner maintaining speed modulating the throttle.
Cheers, Neil |
Not being an expert I do it all the time, you just need a bigger blip. |
Bill, I said going from 4th to 3rd to 2nd wouldn't be useful. I would advocate going from 4th to 2nd with a bigger blip as you say....
Watch Hurley explain it at 12:00 in to this video
<iframe width="560" height="315" src="https://www.youtube.com/embed/YqYeusE8ksk?list=PL1wEuPFICE71g7sjb-TIRIqeN97B-A5Yg" frameborder="0" allowfullscreen></iframe> |
Unless you drive on track, and your pedals are set up properly, or you're ridiculously seasoned at performance driving, you really don't ever have a need for heel toe shifting on the road. It's pretty hard to drive a car aggressively in most places, legally and safely, to the point you'd benefit from heel toe. |
Ok my opinion. Heel/toeing is easier on clutch engagement and transmission scyncros. I heel/toe all the time. Both engines I have installed in my 72 (230,000 miles, 2.4L to 2.7L to 3.0L) the clutch disc looked as good as the new one I put in. Also it's much easier on the transmission. There will come a day when the transmission needs to be rebuilt and guess what is the main part replaced, yep the 2nd and 3rd gear scyncros.
On the track or fast track autox, you what that gear to give you max torque pulling out of the turn. If you just pull it down into the gear you what when you let out the clutch you may find yourself looking back the way you came. Also I have found that in some situations, a high speed straight coming down to a much slower turn I can concentrate more on my braking and then heel/toe down from say 5th to 3rd with out sometimes getting a little unstable downshifting 2 gears. Just my opinion. |
Mechanically heel toe isn't really any easier on the syncros, only double clutching really reduces syncro wear. The syncro bands are to get the tranny main shaft and intermediate shaft at the same speed only double clutching will do this. Bliping just the motor revs will not.
I rev match all downshifts on the street. I will often heel-toe and brake a bit later and harder on the street if no one is around. Practice for the track. Once I get to the track it becomes subconscious after a lap or two. It makes everything smooth like butter.
Shifting down two gears is slow with the 915 if you hit the gear between. Our track only has one area that requires me to double downshift in my 911, and I have done both (skip a gear, or hit the gear in between). For my situation, I am going from one downhill right sweeper to a left hairpin, and the double shift is rushed. Easy place to spin out (and lots do) with a bad shift as you are never really going straight. I have begun to just go 4th to 2nd, skipping 3rd. If it was in a straight line, I might hit 3rd then second. With my 2002Tii there was an area where I would need to drop two gears (in a straight line, 4th to 2nd). I tried skipping 3rd, but my 40 year old synchros whispered to me that they did not much like it. I opted to hit 3rd on my way down and never had another issue. |
Wow. So much misinformation here.
Racers heel/toe when they need to be in a lower gear after braking for a corner to get the best acceleration out of the corner. The reason racers heel/toe is to keep the chassis from getting upset when the drive wheels and engine are reconnected when the clutch is let out. The heel/toe's goal is raise the revs of the engine to match what the revs will be in the lower gear at the car's speed when the clutch is let out. If the revs are not matched, the rear tires will need to speed up the engine and that causes extra load on the tires and transmission. If braking in a straight line, the car can wag its tail and even cause a spin. If trailbraking, a spin is much more likely. Heel/toe does nothing for synchro life. Double clutching (sometimes called Double declutching) on downshifts is the way to increase synchro life. 2nd to 4th downshifts, done properly, are not any harder on a transmission than going through the gears in order. |
Mind you, my Tii just did not like 4th to 2nd, but it was probably driver error. Hitting 3rd probably made me time things better and not rush. |
I have a friend that went to the Porsche Driving Experience at Barber Motorsports. He ended up with none other than Hurley Haywood as his instructor. He was early in his Porsche ownership and Hurley was telling him he HAD to learn to heel-toe. So Hurley demonstrated and my buddy was making valiant efforts to do it right but was not getting the hang of it. His lack of ability started to be a sort of running gag until the lightbulb finally came on for him.
I try to practice at every opportunity. It is like the heavens parted when you finally get it. My brake pedal still seems higher than it should be when fully depressed. I used the Rennline accelerator pedal that raises and extends the side of the pedal and it helps. I keep tinkering with the setup. Still not right to me. It seems like what is comfortable is a little different for everybody though. I still re-read Vic Elford's Porsche High-Performance Driving Handbook from time to time. I think his explanation is the first time I really got the concept. |
I learned how to heel toe watching a video hurley haywood had on youtube with an automotive joirnalist in a 997 gt3. Practiced in my computer sim rig (with clutch and 6 speed) and then the real thing was quite easy.
Just for grins. Not that Scott knows anything about going fast, but his post above is absolutely correct and elegant in its simplicity. (You may thank me later Winders...).
Many people complain about the difficulty of the h/t blip. I simply will maintain that if one cares at all about driving that one should ABSOLUTELY learn to do it, and do it well. There should be no excuse (unless the driver has an ortho problem) for not expending the effort to figure out which position on the pedals works. Some actually heel/toe, others toe/heel, and some roll the slightly angled foot...most do a combination. WHATEVER IT TAKES, DO IT. I tell my students that the roll of the foot can be practiced at all times in all vehicles. It must be automatic and conditioned and as much of a habit as flushing the toilet. Barefoot, in sandals, workboots covered with mud, it can and must be practiced in all vehicles. If your daily driver has an automatic tranny, then the move can be practiced (i.e. rotation of the foot) without actually blipping the throttle. Sitting at a stop in neutral it can be practiced and sitting in the garage muttering "zoomoom" it can be practiced. Flexibility can be improved beneath the dining room table. NO DRIVER can call himself one unless his H/T is perfect, secondary in nature and automatic in all conditions in virtually all vehicles. |
I also point to Winder's post. Great explanation.
...and, for those who missed Hurley's demonstration on the last page of this thread, here it is again. Quote:
The '09+ Nissan 370z (w/ sport package) has a defeatable automatic rev match feature. There's sensors in the shifter (or trans, who knows) that knows what gear you've picked, and the ECU will trigger the electronic throttle to open to the exact rpm needed for that gear.
Seemed like a super gimmicky thing when I first read about it, but dang, talk about a cheat code, it works perfectly in practice. I know for sure the C7 Corvette 7-speed manual does it now, and I think maybe BMW/Mini do it too. Not sure if anyone else picked it up, but all manual cars should do it these days. |
Porsche air cooled trans from 901 thru 911, 915, g50 all consist of 2 shafts, one is locked to the engine via the clutch the other is locked to the rear drive wheels at all times. W/ constant mesh gears, all gear sets(drive/driven) always mesh w/ their mates on the other shaft. the upper shaft is the input shaft the lower is the output shaft http://forums.pelicanparts.com/uploa...1454074970.jpg Only one gear set at a time is locked to the input and output shaft. The sliders slide on a hub which is always fixed to it's respective shaft, both the gear and the syncro have similarly shaped synchronizing teeth, the slider has a female cone and female teeth that match a male cone and male teeth on one side of the syncro, the syncro also has a female cone and tooth set on the other side and the gear has a male cone and tooth set that matches this. The syncro has a small amount of play until compressed between the gear and slider by the slider motion, friction is generated by the male/female cone arrangement on the syncro and gear respectively. This friction initiates the syncronization process which is completed when the syncro teeth can engage the slider completely this allows the slider to complete it's engagement. Ignoring 5,6 and R here is the heart of the transmission This is a g50, the others are similar, the trans is in neutral w/ no gear set locked to the shafts http://forums.pelicanparts.com/uploa...1454075163.jpg To select 1st gear the 1-2 slider is moved by the selector fork to the left, it slides on a hub which is locked to the shaft engaging the syncro cone/tooth mechanism, friction between the cone and slider synchronizes the speed of the shaft and gear, once the speeds are synchronized the teeth can be fully engaged To shift up to 2nd the shift rod moves the 1-2 slider to the right, again the syncro cones contact the mating cone surface on the gear speeding it up via friction so that the syncro teeth can engage and complete the speeding up process, one this is done the slider completes the move fully engaging the 2nd gear a downshift from 4 to 3 is initiated by the shift rod moving the 3-4 shift sleeve on the input shaft to the left, the cone engages the slider via friction speeding the input shaft up to match the speed of the wheel driven output shaft, once they are close to the same speed the syncro teeth can engage completing the synchronization and allowing the slider to fully engage the 3rd gear teeth on the input shaft. An engine blip causes the newly speeded up input shaft speed to match the resulting engine speed w/o undo shock from excessive rotating part acceleration. Here are some syncros and a broken 3rd gear, the gear broke from shock loading http://forums.pelicanparts.com/uploa...1454076714.jpg here a shift fork and a steel syncro(upper) and brass syncro lower, the male half of the brass syncro cone, where the initial synchronization friction is generated, is towards the viewer http://forums.pelicanparts.com/uploa...1454076738.jpg |
If you don't double clutch the syncros have to absorb the energy of any mismatch in gear speed to ensure engagement. The process of absorbing that energy is friction wear. When you double clutch correctly there is no speed mismatch so there is no energy to absorb hence no frictional wear. To put it another way: Is there any syncro wear when you shift a transmission when the car isn't running? No because the relative speed between the engagement slider and the gear being selected is zero. ------------ Also a clarification on your second sentence: Double clutching is a way to shift a manual transmission and it is also required to shift a transmission that lacks syncros, ... Double clutching can be done on most any manual transmission and if you feel the engagement through the shifter it makes it go into gear noticeably smoother and with less force. (Hell, on my truck I double clutch on the up shifts too. A light weight flywheel and doing it for years makes it effortless.) |
Interesting thread... Trying to practice double clucthing while tracking the 930...
It is HARD. Usually the double clutching is needed when you are going into a slow corner, and want to somehow use 1st gear to exit... Getting into 1st gear while driving at speed almost always seems to grind otherwise... But it seems risky... You are flying into a corner, trying to double clutch AND blip the throttle, usually, you are mid turn too... If you screw up the braking, the laws of physics and the immovable object theory will tap dance all over your head... The gears on a 930 are soooo far apart... |
If you are going into a hairpin turn, you generally have to get down to about 30mph in that turn... or less... If I stay in second, and I apply the throttle at the apex, I have lost all momentum... Car is at 3000rpm, maybe... I thought exiting in 1st (good to 50mph or so?) would be quicker... Maybe the key is applying throttle WAAAY earlier, and calculating when boost will kick in... Though that doesnt sound like the best idea (I know the pro's do this)... Would rather be applying throttle when the car is already in a straight line... Open to all idea's... |
