Embarrassed to ask....but I need some help on this
I am trying to recal where the tethers attach to open the deck lid hinge. I know that one side attaches to the main hinge bolt. Does the other side go the the deck lid piston shock mounting point? Seems like the only logical place...
http://forums.pelicanparts.com/uploa...1454188381.jpg |
No such thing as a bad question except for the unasked question.
That is not a tether but a grounding strap. |
Wow- awesome thanks- so I had the first location correct?
On my 1973, there is a strap on each hinge. The strap ends go under bolts that connect each end of the hinge to the car.
I don't have any tethers on my 1973. Should I?
Dick,
I do not know. Only that my car has two. |
It's ground wire on mine for the engine bay light. It can go anywhere metal. If you have a FG decklid, you need to do something else......
| All times are GMT -8. The time now is 08:23 AM. |
