San Diego, CA
Removing Colored Anodized Plating
I have a Nardi Torino steering wheel that has a gold finish on its aluminum spokes which I assumed is an anodized finish.
It is worn in places exposing the silver colored aluminum so I expect it can be removed.
What would be the best way to remove this?
Old 01-25-2016, 03:45 PM
Easy peasy! Get a spray can of EZ OFF oven cleaner. Spray it on, wait a bit and wipe it off.
The "gold" will come off "slick as snot".
When my kids were young and riding BMX bikes, most came with blue or red anodized
pedals, hand brakes etc. They had to be "custom" so they removed the color with EZ OFF. It REALLY works!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 01-25-2016, 04:02 PM
Under the radar
Trackrash's Avatar
Make sure it is the "Heavy Duty" EZ Off.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-25-2016, 05:28 PM
Mick_D's Avatar
AND be prepared for a lot of rubbing and polishing to get the shine back onto your aluminum. It will be milky-white after the lye does its job.
Old 01-25-2016, 06:07 PM
Done it many times, just get a tube of a good aluminum polish and a can of NEVR DULL
wadding. Hit it with the polish first then use the NEVR DULL to finish it off. Takes very little time to get a great shine back.
Old 01-25-2016, 06:21 PM
San Diego, CA
Thanks for the additional suggestions. The Easy Off did not work but thanks. Had better luck with some metal polish and #0000 steel wool but still can't get it all off. Will try the NEVR DULL too but considering wet-sanding with 3000.
Old 01-29-2016, 08:30 PM
Under the radar
Trackrash's Avatar
Did you use the Heavy Duty EZ Off in the yellow can? The other stuff will not work.
Gordon
Old 01-30-2016, 12:38 PM
7.0:1 > 11.3:1 > 7.0:1
Heavy Duty EZ Off in the yellow plastic spray bottle. May take a couple applications.
Old 01-30-2016, 02:03 PM
Been here a while
Otherwise use the super caustic heavy duty greases and hair dissolving drain cleaner.
This is the type typically sold in a nasty looking black bottle encased in a heavy zip lock bag at the big hardware stores.
This will remove the anodize. It will also cause immediate blindness if it gets in your eyes. Massive amounts of caution are required. But it works.
looking for 1972 911t motor XR584, S/N 6121622
Old 01-30-2016, 02:17 PM
Checked out
McLovin's Avatar
I've removed a lot of anodize.
This works best, guaranteed to remove any anodizing, in one application:
No lye
Old 01-30-2016, 02:34 PM
Mick_D's Avatar
Use Aircraft Stripper. Let it sit for 10 minutes. Then use a pressure washer to clean it off.
Old 01-30-2016, 02:36 PM
