ISO: brown electrical tape to match ground wire insulation
Greetings all. I'm not a huge fan of using electrical tape, so if I am going to use some on one of my ground wires, I would like it to match the color as closely as possible.
Anyone have any brand names / part numbers for brown electrical tape in the right hue? Thx, Frank 1988 911 M491 Cab |
here's a link to some 3m brown electrical tape 3M Scotch 3/4 in. x 66 ft. #35 Brown Electrical Tape-10885-BA-5 - The Home Depot
The Amazon link for the Scotch #35 above looks close to the right color - it's got a different picture:
Robot Check
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Schleprock
What about brown heat shrink tubing?
Kevin L '86 Carrera "Larry" |
Or clear heat shrink tubing.
McMaster-Carr.
'90C4 |
Thanks! I thought of that, however it would need to be large enough for the ring terminal to pass through and then I don't believe it would shrink enough to sufficiently wrap the wire.
