-   -   3.2 to ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/901076-3-2-a.html)
enzoducoing 02-05-2016 03:36 PM
Originally Posted by HorstP (Post 8986141)
The cylinder studs need to be moved for this, right?
They don't, but space is tight
http://forums.pelicanparts.com/uploa...1454718920.jpg
Fly911 02-05-2016 04:19 PM
3.2L to 3.8L...
Here are the mods:
997 GT3 crank, knife edged, cross drilled and balanced
997 GT3 Pankl titanium rods, all weighted and balanced (with stronger ARP bolts)
997 GT3 oil pump
997 GT3 Cup intermediate shaft and gears
102mm LN Engineering NiCaSil cylinders
102mm LN Engineering special light weight pistons with titanium wrist pins (balanced to +/- 0.1 grams)
Engine case spigots bored for the bigger cylinders, machined for the oil pump and internals boat tailed
Cylinder heads machined for twin plugs, intake and exhaust ports bigger and polished.
993 RSR valves, 52.5mm inlet and 44mm exhaust, titanium retainers and race double springs
Combustion chamber and exhaust port ceramic coated
Piston tops ceramic coated
Elgin race camshafts, 325 degrees inlet, 318 degrees exhaust (I can't remember the lift)
Pauter racing valve rocker arms
Fabspeed stainless steel equal length headers (42mm ID)
997 GT3 4.0L titanium muffler with center exhaust
48mm Jenvey ITB's with special tapered manifolds (like the picture in a previous post)
LWF and Sachs racing clutch
The ECU is a Canems from the UK, plug and play to replace the old Motronic
This is probably as far you can stretch a naturally aspirated Carrera engine...
Gear Box:
Lower 3-4-5 gears from Guards Transmission
Steel shifter forks and synchros
GT limited slip diff.
I want to keep the 911 as a matching numbers car (VIN+Engine+Gear Box), and with no (visible) modifications on body panels and (impact) bumpers. However, at a later stage I will change all body panels and bumpers with fiber glass or carbon fiber parts, and lexan windows. My goal is 1000kg/2200lbs with the (heavy) roll cage.
Suspension is already Rebel Racing/Bilstein Coil Overs with matching year (1987) 930 Turbo brakes and Pagid Black pads.
I love the "wolf in sheep's clothing" concept, where the car looks completely original on the outside, but what the (untrained) eye can not see, is something completely different!
http://forums.pelicanparts.com/uploa...1454721475.jpg
Rodsrsr 02-05-2016 04:25 PM
^^^^Thats a sleeper for sure! Very nice. any idea of HP?
Fly911 02-05-2016 04:33 PM
I'm hoping for 380 crank HP, but my engine builder estimates over 400... It all depends on the dyno tuning of the ECU! Anything above 325Hp on the rear wheels would be good!
gliding_serpent 02-05-2016 05:28 PM
That is just cool. Would love to pick the brain of that builder.
Rodsrsr 02-05-2016 07:45 PM
Nice build. If I ever get rid of my wide body thats what i'd like to build, an sc flaired sleeper.
enzoducoing 02-06-2016 03:14 AM
Originally Posted by Fly911 (Post 8986482)
3.2L to 3.8L...
Here are the mods:
997 GT3 oil pump
Gear Box:
Hello Fly911
This is going to be a fantastic engine!
When Bill Rudtner dynoed my 3.2 to 3.746 with the ITBs and Haltech management it came to 415hp at the crank at 8,000 RPMS so you are looking at very similar numbers. I eventually changed to 50mm PMO carbs because the engine went into my 1971 911T narrow body "Sleeper" and I wanted to keep it looking period-correct. Mind you, I'm using it as a street engine so I'm keeping it limited at 7200 RPM.
I have been using it with only a longer first gear to make the extra torque less jerky and drivable at street situations and all other gears stock. With this much torque, the stock 2nd, 3rd, 4th and 5th run out of space really quick.
Oh boy you're going to have so much fun with this engine!
Triple cheers !
MD
Porschephanatic 02-06-2016 04:28 AM
Originally Posted by jeffbottman (Post 8984930)
This is a really good thread, lots of useful stuff!! Good work Pelicaners. :)
http://forums.pelicanparts.com/support/smileys/wat6.gif
+1
Subscribed. Could not be a more timely thread. With budget in mind, I'm at that point in my life to upgrade the SC I have or just trade on a Cayman GTS before MY mileage expires! http://forums.pelicanparts.com/suppo...leys/angel.gif
Bill Verburg 02-06-2016 05:20 AM
3.2L to 3.8L...
Here are the mods:
997 GT3 oil pump
Gear Box:
That's a nice(and expensive!!) motor
I'm wondering why a 3.2 case and heads are used
the 3.0/3.2 cases w/ 86mm*stud*spacing*oe use heads w/ up to 39/35 ports and 49.41.5 valves on 3.0s and up to 40/38 ports and 49/41.5 valves on 3.2
the meat at the cylinder bases of the 3.0/3.2 gets awfully thin w/ 100mm bores(3.5l on the long stroke 3.2 crank). I'd limit it to 3.4l, using 98mm p/c and the long stroke 3.2 crank(JMO).
the 3.6 964 moved the*head*studs out to 90mm, these are good for 3.8L w/ 102mm p/c sets, w/ these it's advisable to use 109mm base bore rather than the stock 3.6 107mm. Both are available the 109mm base is just stronger.
scarceller 02-06-2016 08:14 AM
Bill, can the studs be moved in the 3.2L? I know of someone who wanted to put 3.5 964 cyls into a 3.2 and it was advised not to go this route as the studs need to be moved, can anyone in the industry move these studs reliably? or is it simply not possible?
HorstP 02-06-2016 08:36 AM
I have been clearly told that this is possible. I am in the process to decide which route I want to go and it was advised, that while the 3.4l is a plug-and-play upgrade, it will not yield the gains I am expecting. Moving to 964 P/C and installing a GT3 crank is what I should do. I was also informed about which experienced builder would do that conversion including moving the studs but frankly I have not contacted them yet (of course somebody in Germany...)
Fly911 02-06-2016 09:10 AM
Bill, I'm fully aware of the "thin meat" at the cylinder base. I did a lot of research about this, and got very different answers from several reputable Porsche engine builders. I chose to trust my engine builder (Rennspoirt Porsche Works, Sealy Texas), and also LN Engineering. The alternative was 100mm p/c's (3.6L), and LNE had no issues with the 102mm vs the 100mm. They claimed that they had not seen issues with oval cylinders due to thin wall thickness. They also claim that the alloy they are using is stronger than the OEM cylinders, and have far better heat dissipation, with fewer thermal issues. So I hope I have followed the right advice.
The reason why I'm building on a 3.2 rather than a 3.6, is that I want to have a matching numbers car, with a COA from Porsche. Also, buying a 3.6L would cost $8k, and the total build cost would be even more expensive. The cost is crazy enough as it is, I could have bought a brand new and well equipped Boxster for what I'm putting into the engine and gear box!
Tippy 02-06-2016 09:26 AM
Man, I just had drool come out of lower lip. I'd love your engine Fly911, but with lower compression to turbo.
You realize 4-digit hp wouldn't be that hard to hit with a turbo and moderate boost levels?
I understand the need for stock look, just thinking aloud. :)
scarceller 02-06-2016 09:55 AM
Do you need to move the studs to fit these cyls? If so who's doing the studs? I ask because I'm working on a motor that we'd like to know if moving the studs is a option.
Thanks.
Fly911 02-06-2016 10:44 AM
Scarceller, the studs don't need to be moved. LN Engineering makes up to 102mm cylinders for the 3.0 and 3.2 cases with the original stud spacing.
NY65912 02-11-2016 11:07 AM
Originally Posted by enzoducoing (Post 8984134)
Hello
I'd like to share with you my experience between stock 3.6, 3.6-to-3.8, and 3.2-to-3.7 engines.
I have all of these engines currently in my cars. Patrick Motorsports built the RS spec 3.8 from a 964 3.6. They also rebuilt the 993 3.6, and the 3.2-to-3.7 is an engine built by Bill Rudtner that came with a car I bought from Michael Serrone.
To be blunt, the best overall engine, with the most usable torque, power delivery, rawness and monster power is the Rudtner-built 3.7 from a 3.2. It is simply awesome!
The 3.6 and the 3.6-based 3.8 are great but lack the low end of the Rudtner engine, the specs are:
Based on a 3.2 case – boat tailed
3.2 74.4mm crank stroked to 76.4mm Re-nitrate
Using 2” rod journals utilizing NASCAR type rod bearings.
Center drill for better oiling to #2 and #5 rods (special center main bearing) engine able to turn to 8600 rpms, but I am holding it down to 7200 rpms.
Custom Pauter Connecting Rods – using Raceware Hardware
Camgrinder -DC62 profile on a 108° lobe center
Race Springs, Ti Retainers
3.2 Heads – Dual Plugged & Ported
102mm LN Nickies 11.3 to 1 CR
JE Pistons coated
50mm PMO Carbs
Smart Racing Oil Filter Console
1¾” Nabel’s Headers into a custom 2-into-2 banana muffler with interior x-pipe and dual 80mm outlets
Spark controlled by dual MSD
Patrick Motorsports Twin Plug dizzy
Light weight flywheel and HD clutch
When I first bought this engine it came with 52mm ITBs, Haltech management sys and accel coil packs but decided on carburetors and it made it even better.
I am so happy with this engine, that my plans are to replicate it for my other cars and sell the 3.6 and 3.8 engines.
Thats how much difference I see and my highest recommendation for ending up with a 3.7. Build it out of your 3.2.
Cheers
MD
Mauricio, I am so glad that you are happy with that engine. She is scary fast for sure. The low end is amazing and the fact that she can go to 8600 rpm is impressive. We took a lot of time in picking the right components for it to have great power and maximimum longevity.
Best Regards,
Mike
scarceller 02-11-2016 11:24 AM
I've seen a lot of 3.2s upped in displacement and twin plugged but why don't I see any pistons that resemble the 964 piston with the bowl shape on top? That 964 piston bowl was designed by the factory specifically for twin plug, it results in effectively reducing the bore at the top of the stroke and usually allows for less ignition advance to achieve peak torque.
I guess I'm asking if anyone makes a piston like the 964 piston for a 3.2L to 3.4L twin plug upgrade?
Borrowed the pic from another thread:
http://forums.pelicanparts.com/uploa...1099249942.jpg
Here's yet another one for the 964 RSR with valve pockets for high lift cams:
http://forums.pelicanparts.com/uploa...1099250017.jpg
And here's a 993, same basic shape:
http://3.bp.blogspot.com/-ZEYbsV2306...0/tff_1479.jpg
panzerfaust 04-05-2016 02:35 AM
thats a great scarceller.
i have a 3.2 twin plug that may need pistons replaced. does mahle (preferred)or any one make a twin plug piston in 95mm or 98?
scarceller 04-05-2016 04:19 AM
What pistons do you currently run in that 3.2 twin plug?
And what cam?
A lot of folks use the J&E 10.5:1 pistons but depending on your cam choice you could also benefit from 11.5:1
I'm currently helping on a Twin Plug 3.2L at 11.5:1 with J&E pistons and factory cyls. This motor will have a dynamic compression of 8.9:1 on 93 octane. We'll see how this one does on the dyno.
Here's another build, twin plug 3.4L with (soon to be) J&E pistons at 11.5:1 and a more aggressive DC43 cam with dynamic compression at 8.5:1. Engine currently awaits the new pistons and cams. This thread has the engine with the 10.5:1 pistons and the DC21 cams but those are going to be changed very soon:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/871561-1985-3-4-build-using-maf-279-56-hp-237-63-rwhp.html
My points above are that, even though we've seen good results using J&E I question the design when compared to the 964 and 993 factory piston shape.
panzerfaust 04-05-2016 06:33 AM
hi sal
stock usa or euros... hard to tell when the slugs are still in the car.
my first priority is reliable build spec not an all out track motor. prefer mahles, since they were a stock oem company but he shape isn’t correct for twin plug. JE is an option with nice flat tops but I hear folk are weary of the expansion capability of the alloy with the stock jugs that may cause piston slap or knock until warmed up. Any other alternatives for pistons?
Not looking for anything near 11:5CR since im being conservative with poor quality fuel in regions of the usa. No knock sensor, stock cams and stockish motronic (for now) I would like somewhere 10:1 or 10:3 CR. Down the road I may do cams and intake (MAF or ITB)
Ive been down the high CR roughly 10.5’s road before and had to reduce the advance and made the motor sluggish on the low end. the car did make A LOT more power up high though...
regards pf
