static compression ratios mean very little, what matters is the dynamic compression ratio and this is considerably influenced by choice of cam.
What cam do you plan to run? Dynamic compression MUST be in the range of 8.0:1 to 9.0:1 for that motor to generate any decent amount of torque. The single plug usually falls in 8.0:1 to 8.5:1 range while dual plugs are in the 8.5:1 to 9.0:1 range. You can have a static compression of 12.0:1 and still only have 8.0:1 dynamic compression. You can not spec the static compression needs without concidering the cam at hand. Changing just the cams in these motors can easily move you from 7:0:1 to as high as 9.5:1 on dynamic compression! Avoid the trap of assuming you can't run 12:0:1 static compression on 93 octane, or assuming that your 10.5:1 pistons are safe without knowing the cams, that's also a huge mistake! Quote:
stock cams for now...so no help with larger overlap to ease the dynamic compression
Stock cams at 10.5:1 static compression with twin plugs will do well.
| All times are GMT -8. The time now is 11:51 AM. |
