aircooled addict
jimbeaux911's Avatar
Question Custom Fuel lines- any reccomendations?
I am inserting a 79 engine into an 84 911. Everything is ready to go, but I am short on fuel line. The one that runs from the fuel filter to the fuel distributor. I was informed that it is no longer available. So can anyone recommend where I might be able to get this line custom made?
Thanks in advance!
Jim
someday I will actually get to drive a 911
Old 02-08-2016, 06:44 AM
Call Len Cummings aka BoxsterGT...if you seqrch for fuel lines you will see his name. He made mine, lovely guy and does great work, incl. custom. Best way to get him is via email. len.cummings@verizon.net
Old 02-08-2016, 07:13 AM
ditto.
Len did a great job on the lines for my 3.6 transplant. Great communicator and genuinely interested in "getting it right".
Old 02-08-2016, 07:17 AM
aircooled addict
Sounds like a great guy to get the job done and done right!
Thanks for the help!
Jim
Old 02-08-2016, 08:17 AM
I would recommend Griffiths.
Regards
David Yerkes
1987 911 Targa - GP White
Old 02-08-2016, 08:28 AM
That Guy
Techno Duck's Avatar
I replaced the three common ones in the engine bay with ones made by Griffiths a few weeks ago. Very happy with the quality. Pelican sells them or you can buy direct. Happy i did them finally, the T under the intake was done previously but the jumper line between the two rails and the J shaped hose on the outlet of the regulator were original from 1987 and not in very good shape!
https://griffiths.com/product/911-3-2-engine-fuel-line-set-without-gaskets-or-filter/
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-08-2016, 05:09 PM
aircooled addict
I wish they had a set for the 3.0L all I see on their site is the one set for the 3.2L
Old 02-09-2016, 10:33 AM
Give Chuck a call, as he may be able to accommodate your request for a version for the 3.0.
David Yerkes
Old 02-09-2016, 10:36 AM
4flyboy's Avatar
Amazon Hose in Tampa, Florida
Did mine in a couple of hours....there's one guy there they give the 911 fuel lines to.....sorry you'll have to ask.
It's a big operation, mostly hudralic lines for Semi's and such. We're a piece of cake for them.
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-09-2016, 06:59 PM
