Please need help w/3.0 engine not running
Hi- Thank you!! I bought from an estate a 911Sc that has not run in many years- I got it to start but will not stay running-if i pour fuel in flapper and hold open it will run for a then die out- it seems lik it is running lean- i put fresh fuel,new fuel filter,oil- plugs look dirty but i dont think that would keep it from running Please any thought would be appreciated
What year 911SC?
If you do a search here you will find many threads on this. Here's one for starters http://forums.pelicanparts.com/porsche-911-technical-forum/635005-help-me-bring-79-sc-targa-back-life.html |
Ok let me check it out thank you
Nj..
Do u hear pump running with key on and flapper open?
From my seemingly exact experience I found that most of my injectors were plugged up. After sending them in for a cleaning and rebuild the car started up immediately after installing the rebuilt injectors. Hope this helps.
| All times are GMT -8. The time now is 07:52 AM. |
