Offset for 7 x16 and 8 x16 fuchs question
I have just finished restoring a 3.2 911, and have enjoyed every fraught laden day of the project in fact I want to do another but I digress.
Included in the box of bits that was my car is a set of fuchs 7 x16 and 8 x16. However having just restored the rims I have a terrible feeling that they are not from my car at all (this is because the big box of bits had quite a few bits that were not from my car!!)
Can anyone tell me what the offset of the standard 16" x 7 + 8 should be.
I can then go and measure them. Yes there are offset info on the 8's but the paint is still drying and I cannot make it out.
Your help would be most appreciated.
Senn
Old 02-10-2016, 01:12 PM
Fastest Hunk of Junk
7 is 23.3ET, 8 is 10.6ET.
Why do you think they aren't from the car? Aside from those sizes in 16" not being factory available for a 3.2.
-Brent
Old 02-10-2016, 01:14 PM
look for the porsche part #s on the inside pedals -- they should both start with "911" -- post the #s and folks can give you more concrete advice. Keep in mind that if you 911 isn't a widebody, you'll likely need to roll the inside lips of the front fenders to keep the tires from rubbing during sharp turns with the 911 offset 7s in the front.
Old 02-10-2016, 01:19 PM
3.2 Carrera Fuchs
16 X 6 front and 16 x7 rear Fuchs were available as an option on 3.2 Carreras, so it's possible that the 16 X 7s were from the rear of a 3.2, but the 16 X 8s were likely obtained elsewhere.
Bob G
‘87 Carrera Targa
‘74 914/4, much modified
Old 02-10-2016, 01:26 PM
That is an astonishingly quick response, thanks very much.
Bleedsblue: That is exactly what I feared that they are not from my model and that they will not fit having just blasted and repainted them.
First things first, tomorrow I will measure the offset against the et's you have given and see what I have. Next I will fit them without tyres and see what they look like and compare them with the rims already on the car. I will report back.
Thanks again you have all been very helpful and it is my first post!
Old 02-10-2016, 01:48 PM
TheSt|G's Avatar
There is more than 1 type of 16x8s, have any pictures so we could help narrow it down?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 02-10-2016, 01:55 PM
Again, I'd start by looking for part numbers before measuring offset.
911 offset 8x16 fuchs will have either 911.361.020.45 (later) or 911.362.117.XX part numbers and will work fine as rear wheels.
911 offset 7x16 fuchs will have either 911.361.020.44 (early, 77-84) or 911.362.115.00 (late, 85 on) part numbers and will work up front with possible fender rolling needs.
Here's a good chart -- 911 Wheel Weights
Old 02-10-2016, 02:09 PM
gearhead
The 8! Are either 930 wheels or 951 wheels. But they should fit.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-10-2016, 02:10 PM
Agreed, they'll fit a 3.2 either way (though as noted, some have needed to roll for a 7 up front).
If the 7s and 8s have the same (rough) outer lip dimension, you'd have 951 offset 8s (ET 23), which are valuable to those who want to stuff 8s in the front of SC/Carreras.
If the 8 has a deeper lip than the 7, gotta be "standard" 930 ET10s.
-Brent
Old 02-10-2016, 03:12 PM
I have now been able to read the stamped code and the news is very good (I hope).
Fronts are 911 361 020 44
Rears are 911 362 117 et 10.6
So we have a result.
Thanks to everyone for your advice, I can now buy some tyres which is all that is left to be done.
I look forward to the day when I can post an answer to a question.
Old 02-11-2016, 02:10 AM
LJ851's Avatar
There are no real 16x7 and 16x8 Fuchs that won't fit under the SC/Carrera body. You may need to roll the front fenders slightly depending on your tire size and ride height.
Old 02-11-2016, 04:39 AM
scarceller's Avatar
I have a 84 Carrera factory wide body (M491) it came from factory with 7s front 8s rear. Maybe these came off a early Carrera or Turbo (84-85)?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-11-2016, 05:22 AM
GeorgeM's Avatar
Did I miss it... what year is the car?
8x16s were standard on '89 models (with 6x16 up front), optional before that, but not sure when that option started.
The 7s will be fine up front with a 205 tire. I've seen some folks run 225s. but I've never been able to do that without significant rubbing.
If you have 911 8x16s, good for you, as they're not so cheap these days.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 02-11-2016, 05:33 AM
