				Oil cooler upgrade (? about parts from our host)
			Hi -
				I'd like to upgrade to the Carrera cooler on my SC. On our host's site there are a couple options: 1. Full kit as seen here: Late Style External Factory Oil Cooler Kit PELEXTOIL01N - Graf - PEL-EXTOIL-01N | Pelican Parts 2. Cooler with the adapter kit here: Oil Cooler Adapter Kit 100201053 - O.E.M. - 10-0201-053-M260 | Pelican Parts It looks like the difference between the two is the stone guard(s), both don't include the foam seal or horn relocation. Everything else looks the same. Option 1 is $700. Option 2 is ~$400. Am I missing something? -S
	1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html  |
			I believe M260 doesn't include the actual cooler, while the other one does.
	Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe  |
			Thanks Jason.  I'm aware of that.  With the cooler option 2 costs about $400 which is $300 less than the full kit.  I'm wondering if I'm missing something or it's a tax placed on the lazy.
			 My friends call me Phish
			You can always call them an ask :P
			There's no room for logic here.
			Penile Brigade arrival in 3..2..1...
 I guess you could cobble together the parts with the cheaper $200 cooler for about...$200 less...
	Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant!  |
I would agree, I don't expect that the $400 factory cooler is twice as good as the $200 replica...and there are other options if you go into the $700-800 range anyways.
			If you click on the tab titled 'kits and compatibility' below the  image it lists every piece included in the kit.  Looks like everything you need except the foam seal  and horn relocating bracket.  You can use generic stuff from a big box hardware store for that and fab a horn bracket pretty easily.  The other kit doesn't list anything in that tab, but it appears to be only the hoses and lower bracket.
	1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing"  |
			It looks like our sponsor has tidied up the late Carrera style cooler parts into a kit that makes some sense.  I had a horrible time about 3 years ago cobbling together individual parts from their catalogue with the help of one of their salesmen on the phone.  Ended up sending most of it back.
	If I were you, just to be sure, I'd call Chuck Moreland at Elephant Racing and tell him what you need and check the prices. Sounds like all you are trying to do is replace the trombone and on mine I was installing everything from the engine to the front. Good luck. Tom  |
			Scott...would definitely advise checking out Elephant Racing website. They have a great interactive building tool with great illustrations, and it's very informative. You can then decide what you need to buy and from whom.
			 E-85 sippin drunk
			I actually got rid of my engine mounted oil cooler (because it was in the way for a cam position sensor I need for my ECU). I went with (2) Fluidyne oil coolers that I purchased from Summit along with all the lines and fittings. This setup ran me $900. and is FAR superior to the factory setup, and in my opinion, far superior top the other kits on the market. I took measurements of the area I had to work with, and then bought the biggest ones I could fit in there. The fans will be activated by my ECU.
					I know you are not getting rid of your engine mounted oil cooler, but, I have never seen oil temps rise hotter than 230 Deg while idling. Then, when the ECU turns on the fans, within 1 minute, my oil temp is below 210 Deg. That is in stop and go traffic jams in the hot summer days of Atlanta, GA. 101 to 104 Deg ambient. You would only need one of these coolers, and not near as many fittings or line. I would say you could probably source what you need for around $400 or so.... [IMG]  DSCN2294 by Brad, on Flickr[/IMG]
	Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk  |
