Mick_D's Avatar
Tire Diameter questions
What would the impact of putting tires that have an outside diameter of 26.5 to 26.7 inches on a midyear 911 with 930 flares? Isn't stock diameter around 25 inches?
The reason I ask is that the only street tires I can afford to put on my 15x11 rims are 26.7 inches OD. Not sure if there's a clearance issue or not but that extra inch and a half is concerning. Thoughts?
Old 02-11-2016, 01:45 PM
tharbert's Avatar
There's a lot of good info here. Mr. Verburg pretty much sums it up that you should stick to 25"od unless you have a lot of motor.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 02-11-2016, 01:51 PM
Mick_D's Avatar
Yeah I saw that. I was asking for a little more detail is all.
Old 02-11-2016, 01:55 PM
patz's Avatar
Taller tires reduce low end get up and go. Top speed is increased but on a street car who cares.
15 inch tire selection is limited so, buy what you can afford and deal with it.
Speedo will likely be off. I kinda ignore mine and go by my GPS. If the Speedo issue bothers you, send it out to be re-calibrated.
Old 02-11-2016, 02:07 PM
Cars and Cappuccino
tdw28210's Avatar
I was getting ready to figure out how to get 325/50 r15's inside my turbo flared '77, but the tire diameter is way outside what Bill recommends. Back to the drawing board.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 02-11-2016, 03:54 PM
way too big. my 265/45/16s are 25.5 and thats pushing it
Old 02-11-2016, 04:37 PM
would a drag radial be out of the question like a 275/50-15 ? I really dont know how they compare to a normal tire. They are DOT approved so cant handle too bad
Old 02-11-2016, 04:43 PM
patz's Avatar
They pick up street debris like a magnet. Flats galore.
Old 02-11-2016, 04:46 PM
Mick_D's Avatar
plus they throw anything they run over in the street onto your car. Rocks, nails, screws, gravel, etc. in a few months your fenders will look sandblasted.
Looks like I'm getting some cheap rims and spacers, then. 26.7 inc hes for qa 15 inch 60 profile tire. only size that fits.
Old 02-11-2016, 05:21 PM
Cars and Cappuccino
tdw28210's Avatar
All this talk about 15"'s tires being tough to find. 16's selection seems worse to me.
Old 02-11-2016, 05:44 PM
patz's Avatar
Both are hard to find.
Old 02-11-2016, 05:47 PM
Not as it seems
juanbenae's Avatar
5th gear will become even less desirable...
you don't specify if the wheels are fuchs or not. if they are at 15x11 original units you might get a set of four new 16 or 17 wheels, really highend tires, AND pay a month's mortgage if sold.... is the car a turbo for real, or a look 3.0L or the like?
Old 02-11-2016, 05:50 PM
Mick_D's Avatar
The rims are Gotti J55A's, 15X9 and 15X11. The car is a 911S with the all-metal 930 flares . I will eventually buy some nice aftermarkets but for now will probably try to sell the Gottis for race wheels and buy some 17X9/17X8 Euromeisters or Fox Rotas in the RSR finish and use spacers until I can afford 11 inch wide rims again..
Old 02-11-2016, 06:27 PM
Diss Member
Quicksilver's Avatar
I'm pretty certain you would see some serious clearance issues on the front when the wheel is turned. If you put the car through its range of turning and measure from the current tire you will see some of where clearance is a problem. You will also find some clearance problems only by putting them on. When turned to full lock the tire will probably rub the tub.
In the rear you might see some contact at full compression both on the inside of the flare and on the tube side. On the tub side I would think the oil lines would be the first place to see interference. The thing to worry about if tire contacts the flare is that it will rapidly heat the metal and discolor the paint.
Also the whole car will be lifted and if you lower the car to counteract it you are making the problem worse.
I have a set of 205/75R15 off road truck tires on a set of cookie cutters that I put on my car from time to time. The spec says they are 27.1" in diameter. To get them to fit without serious rubbing I have to lift the front of the car about 2/3" and I had to take the fender piece that goes right behind the bellows and push it as far forward as possible and re tighten it. Plus my fenders were rolled to begin with. If I hit a big bump it will still rub the fender in a turn. All of this relates to a narrow bodied car but it gives you an idea of what you are up against.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-11-2016, 11:57 PM
I found the following calculator quite helpful in a recent wheel tire swap on my 535xi wagon. There not many people modding wagons and info is a little scarce. This tool came in handy as the rolling diameters were important in AWD set up. I also used it when ordering my new wheels for my 930. I like the calculator because it expresses any changes in current set to proposed set up graphically and in MM.
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Sorry if this has already been passed around.
Old 02-12-2016, 05:31 AM
Bill Verburg's Avatar
Besides fit and appearance issues here is the effect on performance of using a tall vs short tire. The motor is a blueprinted race SC 3.0 w/ stock gearing
Bill Verburg
Old 02-12-2016, 06:21 AM
VFR750's Avatar
Bill
23" short tire is pretty small. Much smaller than 24.7-25" stock range.
Old 02-12-2016, 07:02 AM
Originally Posted by VFR750 View Post
Bill
23" is the od of a 275/35 x15 Hoosier R6, it's a common fitment on race SC's, I think you can see why
Bill Verburg
Old 02-12-2016, 07:06 AM
Mick_D's Avatar
Oh I wish I could run those Hoosiers! Might have to until I can afford the rims I need
I don't want a race car. I want a street car. Definitely going to have to get different rims.
Old 02-12-2016, 07:23 AM
Mick_D's Avatar
Bill, in the graph, I'm assuming the drker line is the 23 inch right?
Old 02-12-2016, 07:24 AM
