Parasitic draw -- rear defoster??
I recently rehabbed the rear heater fan in my 3.2. The morning after I reinstalled it, the battery was dead.
I found a parasitic draw of more than 2A (!) that went away when I pulled the rear defroster fuse -- the bottom one in the rear fuse compartment.
I'm a little baffled as to how this happened and what I can do to fix it. Anyone else have this problem before?
Old 02-10-2016, 07:53 PM
ROW '78 911 Targa
timmy2's Avatar
Reinstall the fuse and try pulling the relay, might be stuck on backwards.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-10-2016, 10:40 PM
Make sure the plug to the rear defroster relay isn't reversed, it's easy to do. BTDT And it causes a current drain.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 02-11-2016, 06:52 PM
Looks like I did exactly that, reversed the relay. Thanks for the heads-up! That thing consumes a lot of current.
Old 02-12-2016, 03:56 PM
More Likeable IRL
juanbenae's Avatar
dam you, I thought you were talking about my X.... she was a frosted parasitic draw emotionally & financially. but never mind, carry on.. im cool with this...
Old 02-12-2016, 05:51 PM
SoCalSK8r's Avatar
Awesome
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 02-12-2016, 06:49 PM
Yep....after my re-wire I checked for resistance across ground to +12 at the battery before hooking up the battery. Had a few ohms until I pulled the fuse to the rear heater. After careful checking of the wiring found the plug on backwards, even though it has a notch, it's still possible to flip it.
1986 911 Turbo
Old 02-13-2016, 09:15 AM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
We have common ground. The same ex-wife.
1981 911SC Targa
Old 02-13-2016, 11:23 AM
More Likeable IRL
juanbenae's Avatar
Originally Posted by SoCalSK8r View Post
Awesome
I just ordered a pizza that will be delivered to me... it's not gluten free, will have bacon, pepperoni, is warm & no debate prior to calling it in... best pizza ever.
Old 02-13-2016, 07:02 PM
