Still here
Transmission balance point
Ready to drop the transmission.
Where is the balance point of the 915 transmission for jack placement ?
It doesn't matter too much, the tranny doesn't weigh enough to matter. Put the jack roughly in the center and use a free hand to balance it.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Member 911 Anonymous
+1
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Still here
Thx fellas.
I'm doing this solo so trying to prepare for loosening the mount and holding on to the transmission at the same time. Having no confidence in my juggling skills and wary of a dropping transmission while I'm under the car, I think I'll use two jacks to start with. Another question, the 4 screws in the middle of the trans mount, do I need to remove them too ? Last edited by pmax; 05-01-2016 at 10:54 AM.. |
Don't forget to disconnect the coupler from the input shaft, just incase it drops/lowers too much.
If you are keeping he gear box in the car leave the 4 bolts in place to help support the gear box. Gosh, this is really tricky to do it in the car. Take care not to hurt yourself Brother!
Still here
Oh, in that case, No leave the 4 bolts as it is part of the cross member assembly, place support under the gear box, remove the two large mounting bolts then remove.
If I were you, I would rig up a wooden box support to keep the gearbox from moving while you ease it out of the tunnel with your jack. Hate for it to roll off to the side.
Still here
Got it.
I also have the craftsman motorcycle jack which I can use for a wider support base. |
gearhead
Why didn't you drop the engine and tranny together?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Still here
Thought I could get away with not messing with the CV bolts but that turned out fine after all, so here I am. Besides, wrestling a 911 engine off the transmission was something everyone should experience at least once
Still here
... and it's out.
My thoughts exactly Matt !!!!
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Still here
Wasn't too bad really.
I dropped the engine using a jack onto a furniture dolly. The engine balances quite well alone without the transmission attached. And with the engine out, I can work comfortably in the engine bay on the transmission and cv joints. Safety is paramount of course hence the 2x4s under the rear tires and front chocked. Pulling the transmission straight out while supported by the motorcycle jack was drama free and didn't take much time. Took longer to separate the darn speedo wires without breaking the plastic housing ! Last edited by pmax; 05-01-2016 at 05:23 PM.. |
Woo Hoo!
Well, it will be easier to put back in together now :-)
Still here
I like my 2 step drop approach. Yeah, it takes more time but I have that and I spend less time under the car. Last edited by pmax; 05-02-2016 at 10:40 AM.. |
