Turbonut
Raceboy's Avatar
3.2 starter gear ring fits to earlier 911?
Did search, did not come up with anything useful.
I would like to know whether 3.2 129teeth starter gear ring would fit to earlier 911 pressure plate that originally has 130teeth gear ring? Would I need different starter motor too if it fits?
The reason I want to do this is that I intend to use the 129teeth gear ring with EFI (by adding a notch to the flywheel too and use two VR sensors), 130 teeth ring is not usable in 6cyl application (only 4cyl like 944 NA).
I could machine 60-2 pattern to flywheel too but would rather keep as many original parts as possible.
The easiest way would be just to put 36-1 onto crank pulley but since the engine will have retro-look (with twin-plug distributor and all) I would like to avoid such visible EFI stuff..
Any info would be greatly appreciated.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 02-18-2016, 02:54 AM
The 3.2 has two different ring gears. The first was 1970 through 1986 then with the G50 a completely different ring gear, much like and possibly the same as the turbo.
Bruce
Old 02-18-2016, 04:27 AM
Turbonut
Raceboy's Avatar
Thanks for the reply.
I meant the first series with 915. It has 129 teeth but I have earlier 911 one (from 1978 iirc) that has 130. Hence the question.
If it fits, I will make flywheel trigger system similar to 3.2 Carrera with two sensors (speed and ref).
Old 02-18-2016, 05:42 AM
