Rear wiper help Needed
I an trying to wire up a rear wiper motor to the switch in the frt.
I can find all sorts of wiring diagrams for the 84 and up models but nothing for an 83 and down.
My Frt. Switch has 3 poles not four like the later models does anyone have that section of the wiring harness or can pull their switch down and post or send me a picture?
edit ...... the right switch has four tiny connectors
Thanks Lorne M.
83 SC
Old 10-29-2015, 01:58 PM
I went back to 1975 and still found a four pole switch.
53 red/black to fuse 14
53a red/black to motor
31 brown
31b brown/white to the motor in the rear
That's the only mention of it I find in the factory wiring diagrams that I have.
JR
Old 10-29-2015, 02:28 PM
I would still like to see a picture of someone's rear wiper switch pulled down to see where the wires actually go.
Anyone
Thanks Lorne M.
83 SC
Old 12-06-2015, 12:38 PM
Kroon Wire Harnesses
Wiper switch
Hi, Lorne, does your switch have the following terminals ?
31B
53A
31
53
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 12-08-2015, 01:31 PM
No my switch only has three tabs the fourth is jumpered to one tab on the same side.
Lorne M.
83 SC
Old 12-08-2015, 01:44 PM
Am I correct to assume that Porsche doesn't pre-wire the rear wiper switch behind the dashboard?
David Yerkes
1987 911 Targa - GP White
Old 03-03-2016, 10:24 AM
yes, I haven't found any cars so far with the extra wires.
I have had two fellows here makes but the two harnesses needed so that mine would look original.
if you have a/c then the rear condenser has a cut out section
Lorne M
83 SC
Old 03-04-2016, 10:00 AM
