Rear wiper help Needed
I an trying to wire up a rear wiper motor to the switch in the frt.
I can find all sorts of wiring diagrams for the 84 and up models but nothing for an 83 and down. My Frt. Switch has 3 poles not four like the later models does anyone have that section of the wiring harness or can pull their switch down and post or send me a picture? edit ...... the right switch has four tiny connectors Thanks Lorne M.
83 SC Last edited by LM3929; 03-04-2016 at 09:56 AM.. Reason: more info |
I went back to 1975 and still found a four pole switch.
53 red/black to fuse 14 53a red/black to motor 31 brown 31b brown/white to the motor in the rear That's the only mention of it I find in the factory wiring diagrams that I have. JR |
I would still like to see a picture of someone's rear wiper switch pulled down to see where the wires actually go.
Anyone Thanks Lorne M.
83 SC |
Kroon Wire Harnesses
Wiper switch
Hi, Lorne, does your switch have the following terminals ?
31B 53A 31 53
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
No my switch only has three tabs the fourth is jumpered to one tab on the same side.
Lorne M.
83 SC |
Am I correct to assume that Porsche doesn't pre-wire the rear wiper switch behind the dashboard?
__________________ David Yerkes 1987 911 Targa - GP White |
yes, I haven't found any cars so far with the extra wires.
I have had two fellows here makes but the two harnesses needed so that mine would look original. if you have a/c then the rear condenser has a cut out section Lorne M
83 SC |
