Does the flyweel ring gear attach to pressure plate on 2.7 Porsche?
Does the flywheel ring gear attach or bolt to the clutch pressure plate for a 1977 Porsche 911 2.7 engine?
and does the flywheel ring gear usually come in a clutch kit or do you have to buy that separate? |
RETIRED
If it doesn't have a ring gear, use the old one unless it is chewed up. If you don't have one, you need to buy one.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The ring gear drops on over the pressure plate, then that assembly pair is bolted to the flywheel. Ring gears do not come with a new pressure plate. There sold separately if needed.
Mark Jung Bend, OR MFI Werks.com |
