petercory
915 Trans Mount Question
The PET Catalog calls for a total of 4 Concave Transmission Mount Washers (I presume that to mean 1 under the head of the mounting bolt and 1 between the top of the mount and the body mount , per side), The Bentley manual only shows 1 concave washer under the head of each mounting bolt (a total of 2 washers). Which is correct?
Old 03-14-2016, 03:31 PM
you want two washers per side. if i remember correctly there was a service bulletin about this which stated if there was a complaint of mechanical noise from the drivetrain to flip the washers around. i think both ways are ok. i installed mine so the washer in effect hugs the rubber portion of the mount. i think the opposite of my install, was the fix for noise
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 03-14-2016, 03:36 PM
petercory
Thanks, that's the way that I thought that it should be.
Old 03-14-2016, 05:45 PM
80s carreras used a different style of washer on top against the body. It has a hump in it. All the earlier cars only used one under the bolt head.
206 637 4071
Old 03-14-2016, 09:35 PM
81SC's Avatar
Here ya go.
81SC Coupe
Tony Kart/Yamaha
Old 03-15-2016, 02:32 PM
KTL KTL is online now
Schleprock
KTL's Avatar
The hump/bump washer JW describes was started with the G50 trans is used between the body and the trans mount. The lower washer under the bolt head is the typical smooth washer used in previous years.
Bumped washer is 911.375.305.00, smooth washer is 901.305.311.00
I have a rather large stack of those smooth washers if you need a couple. I collected them over the years from people switching to solid mounts (bad idea) or WEVO mounts (they have their own washers included with the mount) and figured they'd come in handy some day.
I always say, NEVER throw anything away from these cars. Not unless it's complete mangled garbage. Let me know and i'll drop them in an envelope for you.
Kevin L
'86 Carrera "Larry"
Old 03-15-2016, 03:07 PM
petercory
Thanks for all the feedback, I've got 3 or 4 extra smooth washers, I was confused by the Bentley diagram vs the info in the PET catalog. Should I install the top washer with the cupped side facing the mount and reverse it if I experience vibration?
Old 03-15-2016, 05:04 PM
