-   -   Checking my work... (http://forums.pelicanparts.com/porsche-911-technical-forum/906446-checking-my-work.html)
zippy_gg 03-16-2016 10:07 PM
Checking my work...
How deep does the shift rod seal should be inside the transmission housing?
It is for the 915 in my 86 cab.
I'd hate to put the engine/transmission back in the car only to find a leak.:eek:
Also, where can I find the 2 bullet nose connectors that plug onto the reverse switch? Mine came loose when I unplugged everything upon removal.
Thanks!;)
timmy2 03-16-2016 10:21 PM
http://forums.pelicanparts.com/9030448-post26.html
Reverse switch pin part number I posted recently.
zippy_gg 03-17-2016 10:37 AM
Thank you Dennis. Parts ordered from PP.
zippy_gg 03-17-2016 10:45 AM
Can anyone help me with my first question?
How deep does the shift rod seal should go into the transmission housing?
Thank you!
john walker's workshop 03-17-2016 11:48 AM
Flush.
zippy_gg 03-17-2016 02:00 PM
Originally Posted by john walker's workshop (Post 9041361)
Flush.
Thank you John. I am about 2.5 mm inside from the nose piece.
Should I remove and install a new seal?
zippy_gg 03-17-2016 07:14 PM
Actually 3 mm deep...
http://forums.pelicanparts.com/uploa...1458267177.jpg
http://forums.pelicanparts.com/uploa...1458267210.jpg
SCrescue 03-18-2016 10:18 AM
That should not adversely affect the functionality of the seal.
NICE 69 S 03-18-2016 10:44 AM
I think you may want to polish the shift fork shaft wherever it contacts that seal. If it is rusty and rough, it is going to leak. In fact, clean up the whole shaft and apply some lubrication before you put the fork into the housing. Any sharp edges will cut up the sealing surface of the seal as you slide the shaft into it.
Bob B
zippy_gg 03-18-2016 03:37 PM
Bob B
The plan is to remove all burrs, rust, and imperfections before reassembling.
Good call on lubing the clutch fork; I didn't even think of that.
