Seat Mounts
I have an 82 930, when I got the car the seats had been changed to a later model comfort seat. I just acquired a pair of 82 sport seats with sliders, problem is the brackets in the car have been modified for the other seats and the sport seats will not bolt in.
I'm hoping someone might have a picture of what the original seat mount brackets in the car look like.
Jim
Old 05-29-2016, 05:14 PM
Discseven's Avatar
Jim... Am dealing with same seat swap (track swap) issue with these tracks (below) as the mounting holes provided do not match each other on either the top or bottom of the tracks. My plan is to drill holes as needed. Might gain some leg room by doing so. (Another issue I discovered was the seat belt mount from one seat to the other was not a simple swap.)
The longer track below had "comfort" seats attached. The shorter track fits '79 930 / sport seats.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-01-2016, 04:54 AM
