-   -   intercooler interchangibility (http://forums.pelicanparts.com/porsche-911-technical-forum/90752-intercooler-interchangibility.html)
RJM3 12-13-2002 09:26 AM
hi hope everyone has a merry christmas!!!!to the point is it possible to just change intercoolers from stock 88 turbo to a c-2 i/c? I realize hose sizes are a ptoblem but i can sort that out...can everything else be used from my stock 3.3 motor??regards jerry
rattlsnak 12-13-2002 11:07 AM
It can be done, but you have to change all the plumbing between the sensor plate and the intake side of the turbo, as well as the output side on up to the cooler. Not just a swap over. The C2T used a complete different style intake, and the I/C actually fits right onto the throttle body, as opposed to the 930 style which used an intake piece inbetween the two.
RJM3 12-18-2002 08:14 AM
Rattlesnake....if I could plumb the intercooler off the 3.6 c-2 can i just use the other components? thanks jer
rattlsnak 12-18-2002 08:28 AM
The only way would be to use the all of the plumbing from the C2. The main problem is the tube that runs from the bottom of the sensor plate housing to the inlet side of the turbo. On the C2, it goes straight to it, on the older ones, there is a tube, than a cast "intake" piece, then another tube down to the turbo. In this intake piece, there is a section that runs over and goes in between the i/c outlet and the throttle body. The C2 i/c mounts right to the throttle body. There would be no way to plumb around the early style intake. So if you change all the pieces over it will work, if not no way.
RJM3 12-18-2002 10:26 AM
Thanks for the timely reply,,,,,have a great Christmas,,,regards jer
