thebondman's Avatar
Send a message via ICQ to thebondman
Question Installing new Billet Sump Plate....what's up with the screen?
I'm installing the Billet Sump Plate and noticed a screen just inside the opening. Is this screen removable? Does it need to be cleaned? Could someone shed some light on this subject. Also, why are 2 gaskets?Thanks in advance.
-BILL
"If you're not living on the edge, then you're taking up too much space."
My 1979 930
1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse.
1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines
2003 Jetta Wagon GLS 1.9L TDI
1993 GMC Jimmy 4x4
St. Louis PCA - Member
Kirkwood H.O.G. Chapter #2573 - Member
Gateway H.O.G Chapter #1337 - Charter Member
Old 12-13-2002, 12:18 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I can't say I know more than what I'd learn from removing the plate. That screen is a catch screen for various junk that winds up there. When I first got my car it was full of sludge.
It would probably be a good idea to clean that out every so often (2-3 oil changes? what's the offcial word on that?)
The 2 gaskets are just to prevent leaking.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-13-2002, 12:44 PM
JWest's Avatar
While "junk catcher" is a great secondary use for the screen to keep big pieces from going into the pump, I believe the screen's primary function is to de-aerate the oil so the scavenge pump gets liquid instead of foam.
James
JWest Engineering
Old 12-13-2002, 12:53 PM
Tim Walsh's Avatar
that sounds like a more plausable explaination for it's use.
Tim
1973 911T
2005 VW GTI
Old 12-13-2002, 01:10 PM
