Always learning
Plating reacting with brake fluid
Quick question:
After electroplating brake callipers, is there an issue with the plating reacting with the brake fluid in the bores. Cheers |
Schleprock
No. New Ate calipers from Porsche are plated. They're plated inside and out since the entire caliper halve(s) are dunked in the plating solution, then assembled after plating.
Kevin L '86 Carrera "Larry" |
I have chromed pistons in my TR4 front calipers and they are fine.
Diss Member
About the only reaction you will get is if you let the fluid stay in the system too long without bleeding it. In truth that reaction is with the water in the system. So bleed the system regularly.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Always learning
Okay great - thanks
