Bland
unclebilly's Avatar
2 post hoist lifting points
I just got my Rotary 2 post hoist working.
Where do I put the pads to lift a 911? I am going to slit some hockey pucks.
Old 08-06-2016, 01:59 PM
Bland
unclebilly's Avatar
Google to the rescue...
2-Post Lift Points with Pictures
Old 08-06-2016, 02:19 PM
Bland
unclebilly's Avatar
It works!
Old 08-06-2016, 03:43 PM
Formerly known as Syzygy
Canada Kev's Avatar
Scott, i guess it's just the later cars that got the factory jack platforms. I wonder when they started doing that...?
I've got got jacking "pads" on each corner of the tub. I'd still use a hockey puck or something to protect the car, though. Must be nice to have the lift installed and operational.
Kevin
Old 08-06-2016, 04:23 PM
drl911's Avatar
If your Rotary lift has asymmetrical arms like mine, you should lift the rear engine 911's backwards due to the extreme weight bias of the car. In other words, put the engine where the lift designer expected it to be.
I lift mine both directions all the time based on which end I need near the tool box and 99% of the time it won't matter, but worth mentioning for safety's sake .....
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 08-06-2016, 04:43 PM
Bollweevil
I do the same with my Rotary lift, i.e. back in although I doubt a 911 will stress the lift whichever way you go in.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 08-07-2016, 06:03 AM
