-   -   Engine number-Is this correct? (http://forums.pelicanparts.com/porsche-911-technical-forum/90818-engine-number-correct.html)
thesey914 12-13-2002 07:29 PM
6372014.
From what I've found from searching -does this engine number break down thus :-
6= 6 cylinders:rolleyes:
3=?
7=1977
2014=2014th engine produced in 1977
I think this is a 2.7 with 175HP
Any information correcting me welcome
Thanks in advance.
Zeke 12-13-2002 08:53 PM
I've spent the last hour searching here and on the web trying to find the data on the various engine numbers. I'm looking at another early car tomorrow with a supposedly 3.0 in it. I'd sure like to be able to lean in there and know that it is was it is being sold as. So, no, I don't have the number right now. Can I print out a chart from somewhere and have it with me to verify? Thanks.
YTNUKLR 12-13-2002 08:56 PM
Almost right!
The 6 is for 6cyl, the 3 is some model designation and the 7 is the year ('77). The serial number is also right, the 2014th '77 911/81 engine built. It is a 2.7L w/ CIS fuel injection and 165 hp.
-Porsche 911, Forever Young by Tobias Aichele
d S coupe 12-14-2002 04:29 AM
The 3 is model #, and in this case a targa. 95% sure.
Daniel
Jim Richards 12-14-2002 06:24 AM
6372014 --> RoW 911 (not an S) installed in coupes. Engine type 911/81, 8.5:1, CIS, 165 HP @ 5800 RPM, 176 ft-lbs @ 4000 RPM.
thesey914 01-16-2003 11:45 PM
6151548
Is this a K-jet engine originally? It has zeniths fitted to it now.
I guess it's the same as the other 2.7 165Hp -just made in 1975
This engine looks a lot nicer altogether than the last
Thanks in advance all you fonts of knowledge.
andyjboy 01-17-2003 02:29 AM
6151548 is a '75 911/41 150bhp @ 5700rpm 8.0:1 version.
Andy Boyle(UK)
'69 911E------------->R
Bobboloo 01-17-2003 03:25 AM
Usually a number like
633****(6) six cylinder (3) type S (3) 73' motor
613**** (6) six cylinder (1) type T (3) 73' motor
623**** (6) six cylinder (2) type E (3) 73' motor
For some reason in the late seventies Porsche changed the rules.
In 77'
637**** was a base model (150HP)not an S
and
627**** was a US S (165HP)
667**** was a 3.0 Carrera
The second digit being six was always a Euro Carrera until the 80's
663**** would be a 73' CarreraRS motor.
thesey914 01-17-2003 08:18 AM
6151548
What if this motor is a European model? The owner says it has zeniths as standard.
I thought all 2.7's were either MFI or K-jetted. Were some of the 2.7's fitted with carbs?
DavidPorter 01-17-2003 02:04 PM
I thought the last carb cars were the Euro 2.4 Ts with Zeniths.
