Aidjusting fog lamps on 1989 Carrera 911
One of my fog lamps is aiming too high. i did some searches, but could not find an answer to how I adjust the height of my fog lamps. The later Carreras like mine have the integrated fog lamps that are somewhat recessed into the front lower valiance.
Any help would be appreciated.
1987 928 S4 - Black 2014 C4s 991 - Agate Grey 2014 Cayenne - Mahogany metallic Last edited by Michael T; 03-28-2016 at 06:19 PM.. |
if I remember right, grab the hole light hosing and bend it up or down. You will have to loose the but nut/bolt on the back a little to do so.
Fat butt 911, 1987 |
Rescuer of old cars
Do you really use them? I have no idea how mine are aimed, I doubt I have turned them on in 2 or 3 years. Worthless things, really, don't help vision at all. May go clubs port style when I paint the car someday.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
There is an obvious bolt to loosen, then move up/down to suit. I leave mine on always along with the headlights to 'improve' my visibility to the other s>>>>y drivers here in Seattle.
83 911 Production Cab #10
Generic but it should work: How to Aim Fog Lights | eHow
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Fog lights have a LOW and Wide, close in, beam pattern, which is why the high beam bulb at reduced power was mostly used in the early days of DRLs.
Recreational User
I just had my valance and fogs off a couple weeks ago. IIRC, there is no up/down adjustment with the way it's mounted, only side to side. The factory aimed them properly, so it's likely that something impacted one of your fogs and it's out of kilter now. To fix it involves removal of the valance and some bending.
There is a nut that you can reach behind the valance, I want to say it's 17 or 19mm. Loosen it, pull the front of the light down, and put downward pressure on it while re-tightening the nut. My driver's side one was totally out of whack when I bought my '87. The valance limits how much downward travel you can get.
You can also remove the black cover and aim the light a little further down, but then you might not get the black cover back on, as it will interfere with the valance.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Rescuer of old cars
Obviously, that is frequently ignored by law enforcement. And if you are going to use them for any reason, thank you for caring about having them properly aimed.
Almost all states REQUIRE that the headlights be used, ON, from 30 minutes post sunset to 30 minutes prior to sunrise. It should be pretty obvious that fog lights can have NO positive effects when headlights are on. So, the only time fog lights can be effective is in foggy (smokey?) conditions in daylight hours and at DEAD SLOW SPEEDS so as to not over-run your shortened distance vision resulting from the low and wide fog light beam pattern. Even here in Seattle that happens maybe once or twice a year. Fog lights on modern vehicles are more of a decorative, styling, aspect since they cannot be powered with low beams off. Last edited by wwest; 03-31-2016 at 12:10 PM.. |
In my view fog lights are not for MY visibility, they are to make me more visible to other drivers. Every little bit helps. Aimed properly they don't blind anyone. Also improves chances that the 55 mph left lane driver will do the right thing and MOVE OVER.
Since the fog light beam pattern is low and wide by design then they will not serve well as DRLs. Certainly not as well as the high beam bulb at low power.
Spiderman
They really are useless, I removed them and had the valance welded shut when I painted my car.
You'd never convince me they help others "see me" when they are below my high wattage H4's blazing away, they work great! Don't worry about alignment, no-one will know. If you think its aimed high, bend it back lower so it "looks" OK.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Recreational User
The purpose of fog lights is to illuminate the lane markings and side of the road, so that you don't drive off a cliff in the fog. That's why the beam pattern is wide and low.
I've only needed mine about 5 times in nearly 30 years in Colorado. I think most drivers use them just because they look cool. |
