Zenith jets question
Due to the great threads here about rebuilding Zeniths, I took it upon myself to rebuild the carbs on my 1970t (believed to be a stock 2.2). Ive had it about two years, but it has mostly been sitting waiting for body and paint work. But now I'm getting it up and running, and the weak point seemed to be the Zeniths. They were popping and spiting under load, but would idle fine.
I did a pretty good rebuild, but left all of the jets set as I found them- Idle 47.5 main 115 Pump jets 30 The enrichment circuit had already been removed. When I put them back on the motor, lots of spitting and popping, and I had to screw the idle adjustment screws out to 5-6 turns to get them to calm down. They would balance, but any load caused them to freak. A call to my helpful mechanic suggested that I needed to bump up the idle and main jets because they were running too lean. I stayed with the 30 pump jets, but ordered up some new jets, so now I'm running Idle 50 main 120 ( I also bought 125's if I need them) Its better, as now I'm at 3.5-4.5 turns out, and they are all balanced. While I was doing that, however, I realized that my air correction jets were 195. I have read as many threads as I could on Zeniths, and it struck me that that may be my problem. Too large an air correction jet could lead to my too lean settings, correct? Should I change them for something in the 170 range? If I do that, should I go back to smaller idle and main jets? Any advice much appreciated! David |
If you don't have a wideband air-fuel sensor and gage you'll have a much harder time tuning them up. The best you can do to richer them up.
120-130 mains with 170-180 air correction 50-52 idles The 30 accel jets are probably too small. I've already drilled mine out to 42. I'm on a 3.0 and it seems to want even more. But these are just suggestions based on my experience on my 3.0. I'm at 162 mains 165 air correction 60 idle 125 idle air correction modified housing using performance oriented kit. 42 accel jets |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
eBay. Search under alfa1750. Many different parts for zeniths. Based in Italy.
Just ordered a set of emulsion tubes. |
My main is 120, with 180 air correction 50 idle 35 accel pump. I'd say go with 115 summer / 120 winter mains and 180 air, if it stumbles on accel then go to 35 accel jets. Bigger air correction leans out the top end, bad on the track.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Aircooled
I let my Zenith's set for about 6 months. I thought I had flushed them out pretty good beforehand but when I went to install them I popped off an accelerator pump cover and it looked like it was half full of baby powder. Even after what I thought was a good cleaning I fought idle pop for a while I kept removing the idle jets and spraying carb cleaner it is now 95% improved. I am running a stock 2.2 with stock jets and the mixture screws open about 5+ turns.
1970 911T Current project 1968 912 Sold in 1985 ![]() 1962 VW Beetle Rag Top Runner ![]() 1975 Mercedes Benz 450SL Runner
