78sc's Avatar
Tie rod castle nut
Hi guys, The new tie rod ends I ordered don't have a hole for the castle nut pin. They came with one of those 'squished' lock nuts.
Guess that's ok?
Phil
1978 911 SC
Old 04-08-2016, 01:54 PM
universeman's Avatar
Probably so...you could always double-nut it if you wanted to
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 04-08-2016, 01:55 PM
76 911S Targa
Is that the same size on the tapered shaft? The new one looks larger diameter.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-08-2016, 04:37 PM
Senior Member
Jdub's Avatar
Is that a Lemforder tie rod end? If not, I would consider purchasing that brand for your application. A lot of crap-a$$ knockoffs that have you crying miles down the road.
'78 Targa in Minerva Blue
Old 04-08-2016, 04:44 PM
78sc's Avatar
That's not a bad idea.
Same size. I just measured it with a caliper. Must be the camera angle.
Yes, it's a Lemforder. Seems like it's well built, just doesn't come with castle nuts anymore I guess.
Phil
1978 911 SC
Old 04-08-2016, 05:19 PM
wayne robson's Avatar
tie rod
Hi ,no need to double nut , these are fine ,will never
come off, torque to 33ft pd.
Old 04-08-2016, 06:35 PM
wrxnofx's Avatar
My new tie rods came with one old style and one new style with the lock nut rather than castle nut and cotter pin. Called our host, host reached out to the manufacturer, and they said this is the new style.
When I tried to install the new style, as soon as the nut bit into the threads both the nut and stud/ball turned, not allowing me to torque it up. Called our host back, and the guy I talked to said to push up on the bottom of the tie rod to push the taper tighter into the strut. I ended up using a floor jack. Worked like a champ. Great advice from the person I talked to!
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-08-2016, 11:16 PM
rnln's Avatar
I used a clamp to clamp it up and tighten it. I also put some liquid lock tight
Fat butt 911, 1987
Old 04-09-2016, 01:04 AM
78sc's Avatar
Thanks for passing on your experience. Much appreciated!
Phil
1978 911 SC
Old 04-09-2016, 06:04 AM
non-whiner
mreid's Avatar
That style actually works better as you don't have to fiddle with torque vs. hole alignment. Also, never use locktite on a nylock nut. The locktite eats the insert weakening the whole purpose of the nut.
"Too much is just enough."
Old 04-09-2016, 07:07 AM
Mine came that way too and just put them on. So far so good and not losing any sleep over it.
Old 04-09-2016, 03:16 PM
78sc's Avatar
Good to know, thanks.
Phil
1978 911 SC
Old 04-09-2016, 06:28 PM
