-   -   Scratching sound in steering column? (http://forums.pelicanparts.com/porsche-911-technical-forum/909732-scratching-sound-steering-column.html)
lucifer572 04-10-2016 06:17 PM
'86 Carerra Coupé.
I've recently developed a plastic scratching sound in the plastic shroud of the steering column when turning the steering wheel. I've been in there to fix the turn signal/high beam switch and have since also added a momo steering wheel. Each time I've been in there I haven't been able to located the source. Any ideas? Thanks boys.
DRACO A5OG 04-10-2016 06:34 PM
It is two things, but most likely the Steering Wheel contact ring.
http://i.ebayimg.com/00/s/MTIwMFgxNj..._id=880000500F
The other as a consequence is the wiper/horn contact switch.
http://forums.pelicanparts.com/uploa...1307395421.jpg
I would replace the first with new that later will help but if the first one is worn it will soon make that annoying scratching sound.
lucifer572 04-10-2016 10:17 PM
Thank you.
Geronimo '74 04-10-2016 10:36 PM
Awesome,
I had the same noise.
Now I know what to look for.
Lyle O 04-11-2016 03:43 AM
Add some conductive grease. Solved my same issue.
911 Rod 04-11-2016 10:43 AM
My sleeve disintegrated and fell through. Just took the steering wheel off and pushed a new one on.
patz 04-11-2016 11:12 AM
If the above suggestions don't do it. It could be that the plastic bearing may be toast. There is a steel sleeve you can push in. Call Glenn Sager at Pelican. Extension 240. Relatively painless, just remove the steering wheel and a few other bits if I remember correctly.
911 Rod 04-11-2016 11:19 AM
This was the sleeve I was referring to.
