lucifer572's Avatar
Scratching sound in steering column?
'86 Carerra Coupé.
I've recently developed a plastic scratching sound in the plastic shroud of the steering column when turning the steering wheel. I've been in there to fix the turn signal/high beam switch and have since also added a momo steering wheel. Each time I've been in there I haven't been able to located the source. Any ideas? Thanks boys.
Old 04-10-2016, 06:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It is two things, but most likely the Steering Wheel contact ring.
The other as a consequence is the wiper/horn contact switch.
I would replace the first with new that later will help but if the first one is worn it will soon make that annoying scratching sound.
'85 Carrera Targa
PCA/POC
Old 04-10-2016, 06:34 PM
lucifer572's Avatar
Thank you.
Old 04-10-2016, 10:17 PM
a.k.a. G-man
Geronimo '74's Avatar
Awesome,
I had the same noise.
Now I know what to look for.
Old 04-10-2016, 10:36 PM
Add some conductive grease. Solved my same issue.
Old 04-11-2016, 03:43 AM
Counterclockwise?
My sleeve disintegrated and fell through. Just took the steering wheel off and pushed a new one on.
Rod
1986 Carrera
2001 996TT
Old 04-11-2016, 10:43 AM
patz's Avatar
If the above suggestions don't do it. It could be that the plastic bearing may be toast. There is a steel sleeve you can push in. Call Glenn Sager at Pelican. Extension 240. Relatively painless, just remove the steering wheel and a few other bits if I remember correctly.
Old 04-11-2016, 11:12 AM
Counterclockwise?
This was the sleeve I was referring to.
Rod
1986 Carrera
2001 996TT
Old 04-11-2016, 11:19 AM
