Aluminium doors -> 959 ?
Hi,
It's been years I had 2 aluminium doors but I've no idea for what.
The weight is in kg.
Any suggestions ?
Right side
left
Old 02-15-2016, 05:33 AM
[quote='charlus' pid='4503154' dateline='1455615592']
Old 02-16-2016, 12:38 AM
Max Sluiter
Flieger's Avatar
Maybe some special edition 964 or 993? I think the SCRS might have had aluminum panels too. Is there a part number?
Old 02-16-2016, 06:43 AM
#rennfrog
Why dont you trust me when i said it was probably 959 ?
Old 02-16-2016, 07:05 AM
I trusted you but a double check is always a good choice
Old 02-16-2016, 08:18 AM
They could just as well be from a 964 racing model. The doors are not the same, one has a reinforcement beam while the other has none.
Many of the aluminium parts were shared over several models and years.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-16-2016, 08:32 AM
Not from any 911, 964 or 993. Most likely from a 959, as suggested.
JR
Old 02-16-2016, 10:33 AM
I would rather be driving
jpnovak's Avatar
Judging by the rounded corner on the lower, leading edge they are 959.
Old 02-16-2016, 12:05 PM
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 02-16-2016, 12:10 PM
Verdict is finally here.
These are 911 SC/RS doors. The corner is modified for whatever reason, probably due to a body kit.
They are also now for sale...
Old 04-07-2016, 01:51 AM
So, how did you come to the conclusion that they were modified SC/RS doors?
I assume the outer skins were aluminum. Was the inner sheet metal stamping aluminum or steel?
JR
Old 04-07-2016, 04:01 AM
a.k.a. G-man
Geronimo '74's Avatar
Maybe because you didn't know for sure??
Probably isn't a really definitive answer...
Old 04-07-2016, 04:06 AM
959 mirrors are mounted further back and higher up. Were these areas welded over and 911 mirrors mounted?
Jason Herriott
1986 951 (5 Speed) - Zermatt Silver Metallic / Black
1987 928 S4 (Auto) - Cassisrot Metallic / Burgundy
1988 911 (5 speed) - Silver/ Burgundy
1986 930 (4 Speed) - Oak Green Metallic / Cork (Wish list! )
Old 04-07-2016, 04:59 AM
The mirror holes in these doors don't match either a 959 or 911SC/RS, so who knows what the reason for the hole location might be, other than some other mirror was mounted.
JR
Old 04-07-2016, 05:12 AM
JR
Simple.
There is a real 2.5ST who received SCRS doors during the 80s not far from my place.
Complicated part was to reach the owner. Then I just had to compare my doors.
The doors are 100% in aluminum. It's not only the outer skins.
Old 04-14-2016, 01:56 PM
