Rod bolt nut torque
1984 Porsche 911 3.2 carrera
Doing engine rebuild, what torque do you do the ribbed nuts for rod bolts |
15# 90 degree swing
Bruce |
is that 15 Nm, and for the rib nuts
Schleprock
15 Nm + 90° is the cylinder head/head stud nuts. The connecting rods are 20 Nm + 90°
The image below is a scan of the '84-'87 spec book ![]()
Kevin L '86 Carrera "Larry" |
Maybe you make the same mistake like many others, even pros. Rod bolts have changed since a while and so you should know this (guess no one uses still 30+ years old bolts)
Roland 930 Turbo '81 Too many modifications to list |
Is the torque 20nm + 90 for the ribbed nuts, not the hexagon nuts
Schleprock
Thanks for adding that Roland. As soon as I saw your tech bulletin with the 00 vs. 12.9 bolts, I remembered seeing that before. I'll save that in my collection of tech info so I don't forget next time.
Out of curiosity I looked in the Bentley 964 technical reference companion book and it was nice to see this tech info was included there as well. Kev
Schleprock
That being said, I do recognize that the bolt bore in the big end of the rod is a relatively low stress area compared to the rest of the rod. Still, I don't think a nut digging into the rod material is a good thing.
Diss Member
Flat6pac was correct for the "00" bolts. He used a pound symbol - "#".
20 Nm = 14.75 foot/pounds so I think a 0.25 ft/lb over torque is ok.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
