Jp-oh's Avatar
86 Starter Issues (I think)
Hello, I have previously experienced the hot start, no-start after long drives where the starter solenoid will not engage the starter (turn key, all systems up but no starter). I had the car on a 3 plus hour drive yesterday and it was nice and warm out.
This morning I had the same symptoms but obviously the car was stone cold after sitting overnight; key on all lights nice and bright, can hear what I assume is the fuel pump, but no starter at all.
In the past as the car cooled the starter would come back to life. I didn't have time to poke around under the car as I had to get to the office. I'll crawl under and have a look tonight. in the past too there I had a loose wire on the starter so I give that a look and give the solenoid a tap or two.
Any other thoughts?
1986 Meteor Grey Carrera - We'll meet again in Valhalla.
Old 04-18-2016, 06:12 AM
no start
I had the same symptoms several months ago....the yellow wire from the ignition to the engine compartment fuse box terminus had a short somewhere along the line (it is part of the 14 wires strand...). We chose to install a new yellow wire by soldering the beginning and the end and disconnecting the yellow wire on both sides of the strand...it took a long time to isolate this problem but it was solved.
Old 04-18-2016, 08:04 AM
patz's Avatar
If stranded whack the solenoid to free it up. A further fix can be the addition of a hot start solenoid available from Pelican. Back in the day it was an old Ford part. Probably now something else. It's a band aid fix but mine has been reliable for the last ten years.
A new solenoid is also an option. They sell a heat shield but have never used one.
A rebuilt starter could be a more expensive option. Do NOT buy a reman from an outside source. They suck right out the box. Try and find an old school local rebuilder. They tend to be the better source as opposed to Manny, Moe and Jack.
There are NO new starters despite how they are labeled.
Good luck.
Old 04-18-2016, 08:16 AM
T77911S's Avatar
the solenoid can also be "rebuilt".
you basically clean and rotate the contacts so good metal is making contact.
search my name and starter rebuild
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-18-2016, 08:23 AM
Jp-oh's Avatar
Aaanndd it decided to start this afternoon.
Old 04-18-2016, 01:44 PM
patz's Avatar
Always does when cold.....
Old 04-18-2016, 01:51 PM
Jp-oh's Avatar
Except this morning after it had been sitting for over 12 hours. Stupid car.
Old 04-18-2016, 01:55 PM
patz's Avatar
Again, whack the solenoid like a redheaded step child.
Old 04-18-2016, 01:56 PM
Jp-oh's Avatar
It's not easy to get a good line on it unless the car is raised but next time it wont engage I'll get the tire iron out like it owes me money.
Most of the time it doesn't get hot enough to strand me but the drive to the lake is 3 hours and it seems to be almost a sure thing after that trip.
Old 04-18-2016, 02:08 PM
patz's Avatar
Back into a space that is on a hill, pop the clutch in 3rd.
Old 04-18-2016, 02:25 PM
no start
Re read my reply...the solenoid is not your problem...it is an issue when your starter is hot not when it is cold...my 2 cents.
Old 04-19-2016, 02:21 AM
