-   -   Hub removal from trailing arm (http://forums.pelicanparts.com/porsche-911-technical-forum/910669-hub-removal-trailing-arm.html)
Forssling 04-17-2016 01:54 PM
Hi All!
I'm working on my 71 911T restoration. Now I am removing everything from the rear trailing arms. I have solved everything but the wheel hub. How do you get it out? Do you use a press from the backside? Or is there another way?
Thanks for any input!
Jörgen Forssling
Göteborg
SWEDEN
BK911 04-17-2016 02:04 PM
I used an old torsion bar as a drift and pounded it out.
kwikt 911 04-17-2016 02:47 PM
Bfh
john walker's workshop 04-17-2016 03:52 PM
Big slide hammer. BSH. Easier with the arm still mounted on the car.
mreid 04-17-2016 04:09 PM
I used a press as I had the arm off the car. The inner bearing race usually comes out with it.
boyt911sc 04-17-2016 06:12 PM
Rear hub removal.......
There are several methods people use for removing the rear hub/s successfully. Your choice would depend on the availability of the tool you like to use. With the trailing arm removed, a hydraulic press is best used. In situ, a big slide hammer, harmonic gear puller, BFH, etc. would be your choices. Take your time and be patient removing the rear hub. In my case, I have all sort of tools (press, slide hammer and puller, etc.) that I tried and used to remove the rear hubs in the past. After you have removed one, the next one would be much easier and less challenging.
Tony
Forssling 04-17-2016 10:01 PM
Thanks All!
The arm is off the car so I'll go to a friend with a press and work from there.
//Jörgen
