'73 911 T Targa
Is it possible to "fix" a fuel tank sender?
My gas gauge hangs up at 1/2 tank. I'm pretty sure it's the sender and not the gauge. The needle will eventually fall below the half-way point, but the tank level at that point is usually below 1/4 tank. So, when the needle is at 1/2 tank, I never know whether I have a half tank or a quarter tank. Determined to fix it, I looked for a new sender, but after seeing the price, I'm wondering if there are any ways to figure out why it's hanging up and correct it. I've had the sender out and I don't see anything obvious. Any ideas?
Old 04-17-2016, 08:34 AM
A sender in the 911,912,914 is constructed of a hollow tube that acts as protection and a guide for the float located inside of it. There are two very fine copper wires that extend from two different connections at the top and bottom of the tube.
The float makes the connection between the two wires. As it floats up and down , the electrical resistance changes. These changes are transmitted to the dash guage, to give you the level in the tank
So , what goes wrong:
1) The float gets worn out and some gas gets inside of it
2) The outer tube is compromised from compression < look for a dented gas tank near the driver side part of the tank
3) The glue/ crimping of the tube components fails allowing the tube to float free < this restricts movement of the float along the copper wires
4) The copper wires fail < does not sound that this is your case, as the fuel guage would not be accurate at all if a wire comes loose
Practicality of repair:
IF you can remove the outer aluminum tube intact with no dents< Remember the float needs a smooth bore to move up and down. THEN you are confronted with really thin wires for the float to rub against. You would have to source this wire, then figure out how to reconnect them at the correct length.
And again, is the float in good condition? If not, you won't find this unless you pick up a bunch of other broken senders.
So can you fix it yourself? Sure, given enough patience, steady hands, and available parts
URO recently sent us their aftermarket sender , to test, and it works like a champ, looks right too. I believe our host sells them now
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 04-17-2016, 09:02 AM
There is a small nut on the bottom that has a washer bent as a keeper. Tap that down and take the nut off. Then pull the assembly out of the housing. There is a float that rides on a center pole. Mine was stuck on this after sitting for 8years and the pole was no longer smooth. Use some carb cleaner and then fine grit sand paper . There are guide wires and some intact a on the float. Make sure they are clean and the wires are situated between the contacts. Mine works good now. Only pic I took.
Old 04-17-2016, 09:07 AM
How much is your time worth?
Not being flip, possible vs time effective is a consideration if it isn't visibly gummed up.
Have you tried grounding the sender to confirm not the gauge?
Old 04-17-2016, 11:08 AM
Alan L's Avatar
Mine has done the same. You can refresh them , pretty much as described above. If you do a search there are a couple of threads on it.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-17-2016, 11:50 AM
I am my 911's PO
'78 SC's Avatar
When you remove the housing take photos and pay close attention to how the wires are routed. Be careful with the wires, they're probably not copper and not replaceable.
Lacquer thinner is excellent for cleaning the accumulated gunk. Also clean the reserve light contacts at the bottom of the sender.
Old 04-17-2016, 02:21 PM
'73 911 T Targa
Well, egg on my face. When I looked on the Pelican Parts site for a gas tank sending unit, the one I saw was the one for the 100litre tank which costs $500. Upon further review, I see one that's $150 which is more manageable. I still might have a go at fixing it if I can...
Old 04-17-2016, 02:47 PM
