How to remove front light housing
Hi
I need to remove the front light housing from the fender on my 1980 SC.
Do I just need to unscrew the bolt in the bottom of the housing or is there more to it?
Old 04-17-2016, 10:46 AM
Yes, just the bottom bolt. Then you can push up gently and voila! (Mine is non sugar scoop.)
Cheers.
Old 04-17-2016, 10:53 AM
Cheers.
This is what I mean when I say housing. Just the bottom bolt in this?
Old 04-17-2016, 12:31 PM
wrxnofx's Avatar
The H4 light has a single screw at the bottom. Remove that screw and the light comes off. Not always easy, either. I almost had to pry mine off.
The H5 lights are a different animal, one where I believe you remove the trim housing first and then remove the light.
I'm sure others will chime in. You don't say which lights you have.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-17-2016, 12:35 PM
I have a H4 headlight which I have removed already. It is the actual housing as you can see in the picture above. It has one bolt inside at the bottom. Is that the only one to remove?
Old 04-17-2016, 12:41 PM
wrxnofx's Avatar
Are you talking about the bucket? The part with the tabs at 2, 4, and 6 o'clock and the wires in it and gasket around it? That is either welded or pressed into place, not sure which. Someone more knowledgeable will chime in I'm sure.
Old 04-17-2016, 12:46 PM
I'm not sure either. Sorry.
Old 04-17-2016, 01:56 PM
You need an angle grinder to remove the headlight bucket from the fender...
Gustaf
Porsche 911SC -81 Euro
Old 04-17-2016, 02:06 PM
Send a message via Skype™ to Porboynz
That bolt is probably holding the bracket for the oil cooler or similar. To remove the headlight bucket drill out all the spot welds after cleaning the paint off to find them, it will then ease out. (I mean come out with incredible difficulty during which you will spill blood) It looks to be in fine order so I have to ask, WHY?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-17-2016, 09:53 PM
Yes I am talking about the bucket. Sorry :-)
The reason why I want to remove it is because of rust around as you can see in the picture below. Looks like it's only on the edge around the bucket/fender but I want to make sure how bad it is.
Old 04-18-2016, 07:12 AM
Well, if the headlight is not falling out every time you brake I would grind out the rust, seal, fill and paint. Looks like the under seal let water through, the other side probably needs checking as well. Removing and refitting the headlight bucket is major panel work and a full repaint of the fender.
Old 04-18-2016, 09:57 PM
