Retired, finally
Another "where does this wire go?" thread
Car is a 1977 911S Targa with 1984 3.2 motor that I bought last year to replace my wrecked 1984 (motor is from that car).
It had been hacked on and neglected by 4 previous owners, so I am working on the electrical and interior currently. The hazard switch was jammed in the ON position, causing a battery drain, so I replaced it over the weekend with a OE Porsche part. I noticed one brown wire with a inline resistor is not connected. This should connect to the headlight switch? There is a dangling wire there as well, with a matching spade connector. ![]() I also found this unused pair coming from the left footwell area. Appears to be red with black stripe and brown. Could not get any voltage. Any ideas on what it might be for? ![]() There is an unused yellow wire under the dash near the radio opening (no radio currently in car). Does have 12V when ignition is ACC or ON. This is the radio power? TIA, Julian
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
The bottom picture looks to be speaker wire - perhaps running to the rear-deck speakers.
1979 911 SC Coupe 2000 VW Passat 1.8T |
Looks like that brown wire with resistor (N6) connects to emergency flasher switch at terminal 58. the other end connects to a red and black wire via (T1f) which connects to terminal 58a instrument light potentiometer (E20), part of the head light switch.
Chris '75 911s Targa |
Radio wire is Yellow.
Ed 1973.5 T |
Retired, finally
Yellow wire = radio √
Brown wire to headlight switch √ I'm still left with the paired red/black stripe & brown wire in black plastic sleeve that goes up into the abyss around the left defroster pipe. Could be speaker wire, but I have not seen speaker wire covered with a sleeve.
When I looked on the schematic, there was a few red w/black wires so hard to tell for sure which one it is.
Retired, finally
I will try pulling some gauges out and see if I can tell where it goes.
Retired, finally
I figured this out after taking the door panels off for replacement (2 large speaker holes hacked into each, and I mean hacked. It looked like it was done by a beaver on meth. Luckily the door panels were not original, so I feel better about replacing them.) I'm using some Sony 6.5" 4 way speakers (that I already had laying around) in the doors, Poly-Planar shallow 6"x9" enclosure speakers on the rear deck, and a Blaupunkt Cupertino AM/FM/CD in the dash. Probably won't be able to even hear it while the motor is running, but it should look good.
