-   -   What is this part? and where does it go? (http://forums.pelicanparts.com/porsche-911-technical-forum/910879-what-part-where-does-go.html)
brentrussell 04-18-2016 06:01 PM
Hi...
Have this part and wondering where it goes and what it's for?.... please help :rolleyes:
http://forums.pelicanparts.com/uploa...1461027643.jpg
http://forums.pelicanparts.com/uploa...1461027659.jpg
ELZ's930 04-18-2016 06:02 PM
Gas pedal rod support
Sent from my "Driving Shoe Phone"
brentrussell 04-18-2016 06:25 PM
At the pedal end or the engine?
ELZ's930 04-18-2016 06:27 PM
Looks like off the pedal board.
Flat6pac 04-18-2016 06:45 PM
It's a support for a long hood door pocket.
Bruce
ELZ's930 04-18-2016 06:46 PM
I think flat 6pac is right.
ossiblue 04-18-2016 06:52 PM
Bruce
This is absolutely correct^^.
It fits on the door near the front end of the long door pocket. The spring arm holds the pocket open when it's tilted open.
brentrussell 04-18-2016 07:08 PM
Sorry but I don't think so... that arm is no spring to hold a pocket up... it's of a reasonable size and would not fit on the end of door etc.
I'm thinking more along the lines to hold a cable... could be engine end?
ossiblue 04-18-2016 07:30 PM
Okay, I only owned 3 long hoods, so I guess you are right.
The spring doesn't hold the pocket up. The pocket has a nylon pin on the end that the spring holds with a bit of tension.
Do a Google search. https://www.lakewell.com/en/porsche/911/65-73/support-bracket-door-pockets-porsche-911-69-73
brentrussell 04-18-2016 07:31 PM
My Apoligies!!!!!!!!!!!!!!
It is a "Left Door pocket support bracket" 90155508700 you were right and I was on a wild goose chase :)... I won't be needing this anyway :)
ossiblue 04-18-2016 08:29 PM
No problem. Guess it would seem questionable if you didn't have a longhood with correct pockets.
brentrussell 04-18-2016 09:33 PM
:) Have a long hood but it didn't have any interior pc's that I recall and I'm fitting RS door panels.
I wonder if this came with the 81SC I wrecked? anyway, will stick it on the shelf with other not required parts.
