'87 911 3.2 Targa (engine noise?)
My '87 911 Targa has 95k miles and has run great to this point. Still running great (starting fine, pulling strong, etc...) but a weird engine noise has developed after it's been running for 5-10 minutes. The underlying engine noise is the same (again, sounds good, very smooth) but it now sounds like a "compressor" is also running. Hard to describe though....... like a whirring noise.
Any ideas? thanks, Dave |
Alternator bearings going bad? Hard to tell from your description.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Is this at idle or running down road? If at idle in garage, is it possible it's warming up to the point that the engine compartment heater blower, which also provides supplemental engine cooling at a certain temp, is kicking on?
Any way to record the sound and post it? Video or WAV file?
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
Running down the road. I don't let the car idle for more than 20-30 seconds then start driving.
I didn't hear anything that unusual, actually sounded good, but maybe that's just my untrained ear. Could be your a/c compressor? Maybe take off the a/c belt, run the engine again and see if sound replicates?
Likewise, it certainly sounds normal, so following Frank's suggestion you could test unplugging the blower motor that JRSIII referred to and see if there is any noticeable change. Good luck!
__________________ David Yerkes 1987 911 Targa - GP White |
Is there an easy way to unplug/disconnect the blower motor?
And even thought AC compressor is relatively new, I've never used the AC. |
To isolate the alternator run it for just a brief moment with the belt off.
1976 911S MidYear Fever is alive and well. |
Just put your hand on it. You'll feel it if it's running. That being said, it's a single 2 pole connector in the back of the heater blower motor if you want to disconnect it.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Yes, there is a white 2-prong connector that runs into the electrical motor. You just need to get a flashlight and look at wires running into the back left hand side of the motor. I suppose there might be a fuse you could pull, but I am not sure what else is depending on that fuse.
Member 911 Anonymous
I do hear what sounds like a bearing when you shifted to the side.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
meaning like an alternator bearing?
another question, does the noise change/dissipate if you depress the clutch? I.e. is the noise engine or transmission-related?
no, once it begins (and again not very loud but continuous), it is steady at a stop or moving
