-   -   Reverse Lockout Pawl spinning (http://forums.pelicanparts.com/porsche-911-technical-forum/911368-reverse-lockout-pawl-spinning.html)
Trippyloaf 04-22-2016 05:41 AM
i just replaced all my shifter bushings - what a difference! But now the little reverse lockout pawl just spins around. I must of knocked it loose(?) when removing the shifter housing. Is there are way to tighten this?
Oh Haha 04-22-2016 09:04 AM
The pawl has a spring that keeps it from rotating.http://forums.pelicanparts.com/uploa...1461341055.jpg
911pcars 04-24-2016 10:16 AM
The rivet must be removed to replace the spring. It's possible to remove the rivet, then replace the spring with a like rivet or equivalent (short bolt and lock nut).
That said, w/o the lock out pawl, the two springs in the factory shift housing that affect 5th/Rev should self-center the shift lever into the 3/4 shift plane when leaving 5th gear.
It's safer to have the lockout pawl, but doable w/o it, but only if you're the only driver. YMMV.
Sherwood
