The relay on the car now is one I believe I purchased from Pelican that had a fuse built into the relay. My original relay did not. I will say that at some time in the past this relay has gotten pretty hot ( maybe when my previous compressor clutch shorted out) such that some the plastic housing surrounding the spade connectors had melted.
Pazuzu is correct.
The old SC schematic has not changed much in the Carrera, and you will find one Carrera schematic that shows a pressure switch the factory never installed. As far as the relay goes, the older metal can relays had a higher amperage rating, the new ones sold do not; I believe Porsche kept the same part number (which is not common) and changed the relay (added a fused and dropped the amp rating). Get yourself a 30-40 amp relay (they are common). Just cause it says P on it does not mean its perfect. |
Went to another source for 86-87 911 A/C schematic diagrams, no second relay for clutch,same as posted.
You talk out of your ass with wind that is not applicable to any routine issue. FOAD. I mean die. Literally. You are an empty, pathetic man without value even within the sliver you deem yourself a demigod. How is this allowed to happen? |
Did you scan that picture with a toaster, Willy?
God damn it. How is wwest allowed to pollute this forum again? Where is Black993, a real moderator, BTW, when we need him?
Bob, why does providing FACTUAL information constitute pollution...? |
So the box labeled Air Conditioner Relay in the 86-86 diagram must be the one in the smugglers box. Before I tapped it yesterday I had no evaporator fan blowing at any speed, no fender condenser fan running and no compressor engaging. After I tapped it everything began to work and proceeded to work as long as I drove the car around. I have not tried it today so I don't know if it will continue to work. Not sure where the front condenser relay is located but I do have a separate fuse on that component as recommended.
Lemmie check what you posted when I get home. Old habits die hard.
Ya gotta love these AC threads:
iwhelan = missing in action llangston1 = keeping a hammer in glove box to bang the relay dave's= in the easy chair Rawknees'Turbo - wins the Pulitzer Corvus Corvax - go pound salt Bob - searches the bleachers for the moderator West - made parole but lost but lost his bifocals Mike - compos mentis Irhmsd & darrin - ran out for bagels sonett43 - tosses a hail mary, of course I fumble it dentist90 - time to turn up the N 2O. |
Not in my '88 971-4 chart indicates that the high pressure switch was NOT used '84-89..... |
Back to my huffin'.... |
BTW a static charge of 80 only says there is at least a little refrigerant in the system. It may be almost empty and show the same static charge depending on OAT. Good luck, Dave |
Damn..!
A big shout-out, KUDO's to Kuehl/Charlie.:o:o The relay in the smugglers box provides power to the front condenser blower, the evaporator blower, and the compressor clutch via the thermostatic switch. All known, to me, schematic diagrams are apparently wrong. |
