This is first time I have ever had to tap that relay to get the AC to work so that was new wrinkle for me. Like I said earlier that relay is only 3-5 years old and I am pretty sure I bought it from our host. The old original was working fine when I replaced it but it did not have fuse protection hence my decision to replace it. As for the amount of refrigerant left in the system I have to assume it was enough to not trip the low pressure switch but I need to put my gauges on it soon. I was just glad to get it working again. I was not looking forward to a major AC rework this year. I have enough other parts still sitting in their box that need to be put on the car first.
As for the continuing saga or soap opera of AC issues that is what is great about this forum. I love reading the threads and participating when I need to. If Kuehl was down here in Tx he would be a very busy man! |
So, why does the 88-89 schematics indicate the use of a binary pressure switch when none are there...???
Shipped only to select countries..?? |
^^^ Langston proved it when he jarred the relay's contact points free, as suggested, and all his inop components (not just the front condenser fan) immediately started working. |
So does that condenser blower relay shown in the '87 schematic even exist? Where is it located?
I removed my bowtie vent below my dash and wonder if anyone knows of a decent remote sensor bulb type temp gauge that could be used by sticking the sensor/bulb in the bow tie hole and the gauge in the ash tray or console and viewed when necessary? The AC temp gauges I have now never want to stay in the vents unless wedged in and then they may be reading vent structure temps rather than air flow temps.
That 80 PSI on both high/low should easily be enough to overcome the low pressure switch cutout. |
Good point RawKnees, I have not driven the car very much and we have had our share of humidity this year already with all the rain and flooding. I sometimes am amazed that it still cranks and runs as well as it does. Knock on wood!
Provide good info, don't rise to the bait of the troll, and don't post goat pr0n in the Marketplace forum. |
No I have not tried to take the relay apart and inspect or clean it. That is a good idea since it is relatively easy to get access to it. thx for the suggestion.
Ditto same time this happens to the compressor clutch. http://forums.pelicanparts.com/uploa...1461843277.jpg excuse the poor image, it was left in the toaster And, its "official" iwhelan's thread was hijacked. Bob, you care to comment on that? Have we violated the rules? Is it time to send in lawyers, guns and money? |
i have in the past, on another thread, noted P had a pressure switch (can't say its binary, certainly it ain't a red dot trinary) drawn in their later year schematics. The schematics are public knowledge (found in shop manuals as well as the world wide webster). Doubt you'd find them in Wiki, probably they have been under the control of NSA, or in the NIST library; you could have filed a form Form G-639 at any time you know. |
Does anyone have access to ones that are actually correct...?? It seems that the wiring in my '88 does not compare to any of the various publicly accessible schematics. |
Well said. Thanks.
