Irhmsd's Avatar
74S rear ride height after 3.2 swap
I guess the 3.2 weighs a bit more than the stock 2.7. As you can see the rear is a tad squatted due to the additional weight of the 3.2. Also, to be fair, the fuel tank is EMPTY, and I mean zero fuel so that will certainly bring the nose down a bit before adjusting. This should be fun. I am letting a qualified shop do this work as math is not my strong suit.
2013 Speed Yellow 991 Cab
1974 Silver 911S Targa 3.2
1997 993 Cabriolet
1958 356A Sunroof Coupe
2002 Rover P38 Borrego
Old 04-24-2016, 03:33 AM
Just drop the front and it will look great!
82 911 SC
Old 04-24-2016, 03:34 AM
Irhmsd's Avatar
Who knows, once the tank has fuel in it (there is zero now), it may look correct.
1997 993 Cabriolet
Old 04-24-2016, 03:58 AM
You'll probably need to move to a bigger rear torsion bar to carry the weight. If you are at stock, the factory went to a 25 rear bar.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-24-2016, 10:08 AM
