Help! Krylon paint on my newly-refurbished Fuchs wheels!
![]() At Freeway speed today, an aerosol can of paint was being butted around the highway, and I was lucky enough to run over it. spraying aerosol paint all over the wheel well, the tire and the Fuchs wheel that I just had refurbished. As you can see from the photo, it covered both the anodized and black-painted surfaces. Since I know that these are specially treated and/or coated, I don't want to use a chemical to remove the paint...nor do I want to use anything abrasive. Is there any magic solution? Thanks Andy |
The anodizing is really tough stuff. Lacquer thinner will take that right off. I've used it on my paint and trim to remove overspray due to a PO. In my experience, if you rub it hard it will remove some of the paint but if you wipe it lightly it shouldn't damage the existing finish. I'd try it on a small area first, obviously.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Yep... Lacquer thinner or Alcohol. Both will clean the paint off the anodizing and if used lightly will not damage the black paint. Just test it on the inside of the wheel to see how it does on the black paint but you should be fine.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
The lacquer thinner won't harm the anodizing, but Im not so sure about the painted area.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I would gently try some gasoline on a rag and see if it remove the primer on both surfaces.
non-whiner
Is the paint that is supposed to be on the wheel catalyzed? If so, reducer will take that overspray right off without harming anything else.
"Too much is just enough." |
Fleabit peanut monkey
No problem using ANYTHING on tire and anodizing. Just be a wimp with respect to the petal coating. Straight rattle can stuff is typically nothing as to strength. You could even try goo gone.
1981 911SC Targa |
What part is anodized and what part is painted? I'm confused. I thought the lips were brushed and the inner spokes were painted.
Sucks hitting stuff on the road. Bain of my existence. Ran over a rake recently. Grrrr. Sent from my SM-N920V using Tapatalk
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car 1985 911 Carrera Coupe-Grand Prix White/Red |
The silver is the anodizing. The black is the paint.
Can be more aggressive on anodized surface and tire as suggested. Cleaner wax on painted petals with plenty of elbow grease. Kerosene may cut the spray paint as well.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Has no idea. Thanks for the info.
To be safe, wax the black and rubbing alcohol the anodized and tire.
Maybe claybar the painted portion? I know you can use it to remove overspray.
1982 911 Targa, 3.0L ROW with Webers |
Senior Advisor
a tip i use is: after cleaning the paint from the spokes you might remove some of the black paint. re-apply black paint and with a clean rag, use the thinner or whatever you used to get the white paint off to clean the rims around the edges, easy and no masking
08 Cayenne Turbo |
Goof off or goo gone and a piece of an old t shirt. Really. Honest.
probably a lot of the stuff mentioned above will work. the product made to do the clean up you have is called wax and grease remover. you buy it at a auto paint supplier, bob
Just be sure to test a small area of the painted fuchs first. Neither will damage anodizing.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Reducer.
Of the many suggestions for removing the spray from the black paint, make a list, then prioritize from mild to aggressive. Begin at the top of the list.
Sherwood |
Mr. Clean Magic Eraser.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
