8 x 16 Fuchs
Can anyone tell me what these Fuchs came off of. Part # 911361020 45
I think they are correct year for my car 1984.
This is what i found
![]() Did they come off a 911 or 930? |
to answer your second post, Yes, they came off a 911 or 930 (per the part number)-- you'd need to look at the date code (on the inside near the center of the wheel) to get a better sense of which -- believe 16x8 were used on earlier 930s and later (88-89?) 911s
911T '72
They changed the partnumber to 91136211700. It's a 930 wheel from the 80's.
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
The date code is from 1980
I have the same 8x16 fuchs on the rear of my "narrowbody" (not turbo look) targa and they fit fine -- they'll work fine on your '84.
911 offset 7x16 fuchs (which were a frequently ordered option for our carreras) will also work up front on our cars, though certain tire combos may require rolling of your inner front fenders to avoid rubbing. |
