How could fuel lines be run down the tunnel?
In my '75 hot rod someone ran the lines (feed and return) down the tunnel......inside the boxed reinforcements in the top corners of the tunnel (one line on each side, inside the box). Is that normal? I want/need to weld on that area (yes I saw recent posts about that). I am wondering if moving them down to just lay in the tunnel is better??
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 04-27-2016, 02:03 PM
On my '74, both feed and return are run down the driver side thru a "tunnel within the tunnel".
Old 04-27-2016, 02:36 PM
gliding_serpent's Avatar
Yeah, both should be on top side of drivers tunnel.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 04-27-2016, 04:33 PM
