Really dumb pulley question
Hi guys
Just replacing the alternator pulley on my 82 sc. The previous pulley disintegrated.... ![]() So I sourced an identical pulley, got the fan boss welded (as advised in here) and have reinstalled; ![]() So Im now wondering if the pulley arrangement is wrong, and maybe thats why it failed in the first place, but cant really work out how it should go together. The car originally had an air pump, but this has been removed. Im thinking that maybe I should get the single pulley... I cant see in theory why a double pulley with one belt should be a problem... Anyway, I would welcome any comments on the arrangement in place Cheers Kevin... |
I have a 78 sc and have had a double pulley for eons , absolutely no issue . I considered going to the single for looks only but never bothered.
I didn't think the 82s had an air pump. I thought they had gone to the lambda sensor by then and did away with it , you learn something every day ![]()
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
It's hard to get the pulley alignment wrong if the fan housing is seated correctly, while there is absolutely no issue using the two belt pulley I would put a single in for aesthetics (and it weighs less too!)
Gary R. |
Air Cooled
I've got a '78 running the double pulley with the single belt and haven't had any issues.
I, unfortunately, have to re-install the air pump every single year to pass emissions (which sucks given that the air pump isn't really connected, it just looks like it is, and I pass).
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Im still confused about this bloody pulley, and its driving me dememneted...
Does the 'double pulley' consist of the standard half pulley AND the larger pulley that was fitted to my car i.e. are two pulleys (or half pulleys) fitted. My car was fitted with one part - which I think should have been fitted with a second half pulley. But I cant find any diagram/photo/ thread that supports this.....! |
76 911S Targa
Yes. The inner half pulley mates with the half pulley which is the fan hub. The shims determine the distance between the halves and thus the tension on the belt. The air pump pulley is outside that half pulley and drives the air pump belt. There is not a separate fan belt pulley, just the two halves described. If you have AC drive belt then there would be another pulley as part of that system.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Mighty Meatlocker Turbo
Ok, that makes sense, but surely the widest groove possible is the width of 6 shilms - is that enough?
Giess I will have to have a play with he car tomorrow and see if it works! Thanks guys, much appreciated... |
Thread Tools | |
Rate This Thread | |
