-   -   How many here have experienced DME relay failure? (http://forums.pelicanparts.com/porsche-911-technical-forum/912411-how-many-here-have-experienced-dme-relay-failure.html)
widgeon13 04-30-2016 06:07 AM
Did it occur while driving or at start up.
Is this the most common cause of start up failure in your opinion?
trader220 04-30-2016 06:22 AM
Start up
Eric Hahl 04-30-2016 06:24 AM
Start up here as well.
ssupman 04-30-2016 08:06 AM
Dme
Start up.
JAR0023 04-30-2016 08:21 AM
Startup.
NSJ-911 04-30-2016 08:48 AM
Ditto.
Arne2 04-30-2016 08:49 AM
Start up for me as well.
wwest 04-30-2016 09:53 AM
Intermittent until it wasn't..
patz 04-30-2016 10:23 AM
Both. While driving it ended by being a bad/worn fuse on the end from spinning to free up corrosion since I am near the ocean.
I got rid of the problem by going to the updated fuse box using bladed fuses.
cabmandone 04-30-2016 10:25 AM
Dead on startup.
DeRRis 04-30-2016 11:23 AM
When my car was delivered it would not start. Even though the PO had driven the car onto into the transport trailer. It was de DME relay.
Dooodahman 04-30-2016 01:58 PM
Driving. Turned off when stopped at a stop sign.
300cd300sdl911 04-30-2016 02:35 PM
Just last week - start up 1985 911 euro. Changed DME fired right up!
jeffbottman 04-30-2016 02:42 PM
How hard is it to change? Can it be done at the roadside, and where is it? Sounds like I should be carrying one!
Techno Duck 04-30-2016 07:20 PM
Pretty simple, its under the drivers seat next to the DME. If you have 4-way power you can lift the height of the seat up all the way to get more room for easier access. Reach from behind and pull the plug off. Then from the front you can remove a 10mm nut that holds the relay down to the floor.
rokemester 04-30-2016 07:26 PM
just picked one up from our host and it's in my glove compartment. I feel better;)
Canada Kev 04-30-2016 07:37 PM
Put it in your car and try it out. It'd kinda suck to need one sometime and find that your shiny new one you got as a spare is DOA. Doesn't happen a lot, but it does happen...
rokemester 04-30-2016 07:44 PM
Good point...that's why I love this forum.
sky1jord 05-01-2016 08:14 AM
Startup 12 yrs ago. Had no idea what the problem was, so I had it towed to a dealer to get ripped off there. I now carry a spare.
11and14 05-01-2016 09:42 AM
Start up, also carry a spare...
AVIMAX 05-01-2016 09:50 AM
While driving, Disengaged the clutch to change gears and the engine just died. Came to a stop and started the car OK. It did this 3 times within about 5 minuets, the last time it would not start anymore. Towed it home, got a new DME relay and all was good again.
NY65912 05-01-2016 09:58 AM
Start up.
Bought a new one, the Porsche relay was NG right out of the box. I used a Kaehler all good. I keep 2 in my tool bag just in case.
tmadden2 05-01-2016 12:06 PM
Driving. About 15 miles from home and got flatbedded back. Didn't know what the DME was or did, so didn't have a spare. Ordered one online, changed it out a few days later, started right up without any problems.
Raleigh993 05-01-2016 01:11 PM
Start up. Need to buy another spare.
gerry100 05-01-2016 01:29 PM
First one caused intermittent misfire and spark cutout at speed.
Second one cut out on a hot day just down the road from where the car heat soaked in a parking lot . After cooling off it restarted.
My understanding is that the relays fail from cracked welds resulting from vibration.
Somebody here has posted a fix if you're good with a soldering iron.
myself, I just keep a spare in the glove box
